Dual sensor Dual head motion light?
Discussion in 'Electrical Forum discussion & Blog' started by sandyman720, Sep 26, 2007.
  1. sandyman720
    sandyman720 New Member
    Mar 5, 2007
    Are motion lights made that have 2 lamps and 2 separate motion sensors?
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    I have installed a dozen motion sensors on just one head so I would think that you can arrange them in the fashion your mind can imagine.
  4. sandyman720
    Mar 5, 2007
    I want 2 lamps and 2 sensors on 1 mounting. That way I can put it on the eve overhang and aim 1 down 1 wall and the other down the other wall.
    Do they make them like this?
  5. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Yes
    If you have two sensors in the same spot they will over ride each other.
    EDIT for spelling
    thought that you spelled 2 as tow
  6. jadnashua
    I've not seen one like that...doesn't mean they don't exist. Simple answer, install two separate units.
  7. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    The problem with two sensors and two heads at the same location is they will interfere with each other. Either both lights will come on at the same time or one light will tell the other sensor that it is daytime and it will not work.
    I have installed sensors all around a building so that any movement will turn on all the lights through a contactor.
  8. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Couldn't you just wire one sensor to one light, the other sensor to the other light? No seeing why there'd be interference in that case...
    Of course, I'm not sure they make a 4-hole lampholder cover, which you would need for that setup.
  9. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Yes and I have done just this.
    The problems I have found is that one sensor comes on and tell the other sensor that it is day time so it doesn't work.
    Then if something is in the motion range of both sensors then both lights come on which defeats the purpose of two sensors.
    The best outcome would be one sensor and two lights.
  10. sindikeesan
    sindikeesan New Member
    Oct 18, 2012
    Michigan
    How do we wire two (outdoor) remote sensors and one 2-way (or two 3-way) light switches to control one light fixture?
    What readily accessible brand/model would work best for this?
    We want the porch light to come on when someone exits the house onto the porch, or approaches the porch from outside, with manual override. The porch light will be placed so as to shine on the steps and front walk.
Similar Threads: Dual sensor
Electrical Forum discussion & Blog Dual oven with 6 wires Nov 10, 2016
Electrical Forum discussion & Blog Dual switches not working correctly after light modification Jul 19, 2015
Electrical Forum discussion & Blog Dual Trip Breaker Replacement Jan 25, 2015
Electrical Forum discussion & Blog 3-way, dual timer switch wiring Aug 31, 2013
Electrical Forum discussion & Blog weird wiring and wierd voltages on 3 dual switches... Dec 17, 2012
