What is the interpretation of International Residential Code (IRC) SECTION M1502 CLOTHES DRYER EXHAUST guidelines:
Exhaust ducts shall terminate on the outside of the building or shall be in accordance with the dryer manufacturer’s installation instructions. Exhaust ducts shall terminate not less than 3 feet (914 mm) in any direction from openings into buildings. Exhaust duct terminations shall be equipped with a backdraft damper. Screens shall not be installed at the duct termination
My neighbor was cited for a local code violation because his dryer vents outside through the exterior wall which is between the bathroom window and the laundry room window. Both windows are located up high in the wall, more than 3 feet above the dryer vent termination, but the vent is laterally (measured straight across the floor line) less than 3 feet from either window.
So, If you put the end of a tape measure on the center of the vent opening and extended the tape out 3 feet, you would move in an arc that would not intersect either window at 3 feet away from the vent. The phrase "in any direction" leads me to believe that the vent only needs to be 3 feet away from an opening in any direction, not over horizontally 3 feet (regardless of the actual distance of the opening from the vent.)
Any thoughts on how this is interpreted in your part of the country. I am in AZ.
