Dryer Static - modify dryer grounds....amicrazyorwhat?
Discussion in 'Electrical Forum discussion & Blog' started by jgold47, Nov 29, 2013.
  1. jgold47
    jgold47 Member
    Nov 30, 2010
    Detroit, MI
    Now that the wife wont let me use dryer sheets or anything similar on the new baby clothes, the static is driving me nuts. I've tried all of the prescribed methods - vinnegar, dryer balls, aluminum foil (more on that) with no success....came across a length of stranded copper grounding wire from an old project. What about modifying the dryer to have a greater grounding potential? I'm not talking about the motor which would still be connected to house ground,, but introducing some sort of chassis ground with a super low potential directly to earth (in this case to a blackpipe running overhead, which is not tied to house ground...
    I havent dug into the wiring diagram for the dryer yet, although I suspect there is a ground connection from the drum to the normal chassis ground. I want to isolate that into its own ground. Any thoughts?
  2. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    I doubt grounding the drum will help. It's the fabrics rubbing together that causes the static.
    I put only clothes in the dryer and don't get *any* static anymore. The things that helped were:
    - avoiding synthetic fabrics (and wool).
    - using less detergent.
    - throwing in a big worn out cotton towel with every load.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    The tub turns around and around so to try to attach a wire to it would only cause the wire to wrap around the tub until it pulls free.
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    The Drum is already grounded thru the Drum Bearing.
    Some dryers do have humidity sensors in the drum, and you can put the dryer on less dry.
    The dryer you dry the cloths the more static charging. Just do not dry them so long, save power.
    All You can do at this point is say Yes Dear.
    Enjoy the Baby.
  6. jadnashua
    There are some hypo-allergenic perfume free fabric softeners out there. I use All, unscented....normal ones just make me itch all over.
  7. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    Yes, enjoy the Baby. If static cling is all that's bothering you, then you're doing all right.
  8. jgold47
    jgold47 Member
    Nov 30, 2010
    Detroit, MI
    thanks everyone. I stumbled upon the wiring diagram for the dryer, and correct, it grounds through the drum, and actually back through the white wire to the panel. Adding or changing that around would likely have more issues down the line. I've tried using vinnegar in the wash and it seems to help. I guess I'll stick with that for now. I've also gotten these (allegedly) metal impregnated cloths that seem to be helping as well.
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Great if it works for you.
    Vinegar is used to set color in fabrics. I would not mix any New color fabrics.
    Acid can be hard on the Mechanics also.
    Enjoy.
  10. jgold47
    jgold47 Member
    Nov 30, 2010
    Detroit, MI
    youre using an extremely dilute amount of 5% vinegar. I'm guessing areas of the country have more acidic water than what this dilutes to.
    assumedly, everything I'm washing is color safe.
  11. bartstop
    bartstop New Member
    Dec 22, 2013
    Electrician
    Kansas
    I'm allergic to dryer sheets. Haven't used them in years. I don't even notice the static electricity anymore.
Similar Threads: Dryer Static
Electrical Forum discussion & Blog NEED HELP!!! Having problems with dryer/amps to dryer I think.... Feb 12, 2016
Electrical Forum discussion & Blog Need branch ckt diagram for instllation of washer/dryer for permitting Dec 14, 2014
Electrical Forum discussion & Blog Dryer cord - 3-wire vs. 4-wire Nov 27, 2014
Electrical Forum discussion & Blog Old fuse box blowing large fuses but turn on dryer and power is back on? Dec 20, 2012
Electrical Forum discussion & Blog Burning Smell & Banging When Turn Dryer On Mar 27, 2012
