Dryer feed, how far is too far?
Discussion in 'Electrical Forum discussion & Blog' started by acr_scout, Mar 12, 2011.
  1. acr_scout
    acr_scout DIY Junior Member
    Apr 28, 2010
    Manassas, VA
    Hello,
    I am considering moving my laundry from the basement to the living level. (Gotta keep the wife happy).
    I have two questions
    1) How far is too far to run 10/3 cable? It looks like I will need about 70' to get from the box to the new dryer point.
    2) If the distance is not too far, do I have to drill every floor joist or can I nail up so 1x4 and surface mount the cable?
    Thank you,
    Fred
  2. jadnashua
    First, what size circuit breaker does the dryer require? That, along with the length, will determine what size wire gauge is required. 10g may be too small.
  4. acr_scout
    Apr 28, 2010
    Manassas, VA
    30 Amps 220 v
  5. acr_scout
    Apr 28, 2010
    Manassas, VA
    30 Amps 220 v
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    nail the 1 by then install the 10/3 on top (or bottom depneding on you outlook)
  7. Bobelectric
    Bobelectric Electrical Contractor
    Feb 16, 2009
    Eighty Four,Pa. 15330
    Drill It!.......
  8. teamo
    teamo Member
    Jun 26, 2005
    Massachusetts
    Use the #10 copper and a 30 amp breaker and you should be fine.
Similar Threads: Dryer feed
Electrical Forum discussion & Blog NEED HELP!!! Having problems with dryer/amps to dryer I think.... Feb 12, 2016
Electrical Forum discussion & Blog Need branch ckt diagram for instllation of washer/dryer for permitting Dec 14, 2014
Electrical Forum discussion & Blog Dryer cord - 3-wire vs. 4-wire Nov 27, 2014
Electrical Forum discussion & Blog Dryer Static - modify dryer grounds....amicrazyorwhat? Nov 29, 2013
Electrical Forum discussion & Blog Old fuse box blowing large fuses but turn on dryer and power is back on? Dec 20, 2012
