Drum Traps
Discussion in 'Shower & Bathtub Forum & Blog' started by Steven Graham, Oct 2, 2005.
  1. Steven Graham
    Steven Graham New Member
    Oct 2, 2005
    Our bathroom tub has an old drum trap in the floor that serves the tub and bathroom sink. Our home was built in the 1920s and the trap is probably the original. We are constantly having trouble with slow drainage. Drain cleaners provide some relief but only temporarily. Access to the trap is through a small hole which was drilled by a plumber since he was unable to access the top of the trap. It serves as access for a snake but is not convient.
    Is there a better to way to clean it out, or even better, is there a replacement part that I can install.
  2. Terry
    Aug 17, 2004
    A wet vac should help. Plug the overflow on the tub, and vacuum from the drain.
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    drum
    Can you actually see two drains going through the trap?
    Is it a cast iron drum trap or a second story cast iron p-trap?
    How do you know that both drains go through the one trap if you can't see more than a small hole in the floor?
Similar Threads: Drum Traps
Shower & Bathtub Forum & Blog Weird gunk from old drum trap Nov 4, 2016
Shower & Bathtub Forum & Blog Replacing shower drum trap Oct 21, 2016
Shower & Bathtub Forum & Blog Installing new tub drain around a lead drum trap May 8, 2016
Shower & Bathtub Forum & Blog Drum Trap Replacement & Vent Help May 21, 2014
Shower & Bathtub Forum & Blog Bathtub conundrum May 25, 2011
