Drop-In Sink Installation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rmberry79, Jul 20, 2009.
  1. rmberry79
    rmberry79 New Member
    Jul 20, 2009
    First, I appologize if I am posting in the wrong forum/section. If so please point me in the right direction
    This question relates to the installtion of a drop-in sink in a laminate countertop. I have the sink installed. I put plumbers putty under the lip and followed all directions as best as I could. The sink however does not sit completely flush with the countertop. There is a gap between the countertop that measures anywhere from approximately less than a 1/16 to 1/8 of an inch. Just enough that I can see the putty. I always thought that the drop-in type sinks were supposed to be completely flush. Am I wrong or is the gap that I described ok. The only correction I can think of is that the cut-out is not big enough and is binding the sink or that I put too much plumbers putty. I doubt it is the putty problem. Any suggestions or comments welcome and very much appreciated.
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I would think the hole is a little small, did you cut it per mfr. specs?
  4. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Lav or kitchen? Stainless or cast?
  5. rmberry79
    Jul 20, 2009
    Thanks for your replies. It is a stainless kitchen sink. I thought it might be cut a little small also. I did the best I could cutting to the mfg. specs. However, my hand isn't very steady. I thought I might take it back off and try to sand the spots that were tight to the sink. Any insight would be appreciated. Thanks again.
  6. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Did you use the template that should have came with the sink?
    Are all the hold down clips tight?
    Get rid of the putty and use clear silicon caulk.
    Lip should be tight unless you got a sink thats bent, luck. :)
  7. hj
    sink
    Put the sink in the opening without any putty or sealant and see how it fits. It should sit on the countertop without a gap. Putty, especially if it is not fresh, may not compress fully, nor is it the material I would use. A tub/tile caulk will seal the rim and be easier to clean up than silicone.
Similar Threads: Drop-In Sink
Plumbing Forum, Professional & DIY Advice Any good way to stabilize a tall kitchen faucet from flexing a drop-in SS sink? Sep 25, 2011
Plumbing Forum, Professional & DIY Advice 25"x22" Stainless drop-in sink in 27" sink base cabinet? Aug 27, 2010
Plumbing Forum, Professional & DIY Advice How to reattach a drop-in sink? Oct 2, 2005
Plumbing Forum, Professional & DIY Advice Converting a Sunken Tiled Roman Tub area to a Drop-In Tub Mar 29, 2015
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Today at 1:36 PM
