Drop Elbow for shower bar rough in
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Xenomorph, Nov 10, 2006.
  1. Xenomorph
    Xenomorph New Member
    Jul 10, 2006
    I am curious about roughing in a drop elbow for a sliding shower bar. Do you rough in the drop elbow flush with the face of the studs or is the depth not that critical? There will be backerboard and tile going on infront of the drop elbow, and then a drop elbow trim piece and nipple going into the drop elbow.
    Thx
  2. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Depth is dependent on how much room the fixture allows. You can buy or have made nipples to any length, from a minimum value (which I don't know) to pretty long. If the fixture's socket is flush with the back of the fixture, then the drop elbow may have to be deeper in the wall than even with the face of the studs. Doesn't your fixture come with installation instructions?
  4. Xenomorph
    Jul 10, 2006
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I called Moen customer service (800-BUY-MOEN, 800-289-6636) and got some help. Their advice is to make the end of the nipple flush with the finish wall. So, I would buy the shortest brass nipple I could find, screw it into the drop ell (I'm assuming this is brass) (may as well make this permanent -- use Teflon tape and pipe dope), and then mount the thing so that the end of the nipple will be flush with the finished wall. Then wrap the exposed end of the nipple with Teflon tape, add a loosely-fitted (so as not to disturb the tape) cap, and build your wall. Remove the cap, glop some pipe dope on the female threads of the Moen drop ell, and screw it on. It's supposed to tighten just as the flange comes up to the wall.
    Good luck...
  6. Xenomorph
    Jul 10, 2006
    wow that is above and beyond, thx alot for the info
Similar Threads: Drop Elbow
Plumbing Forum, Professional & DIY Advice Drop ear elbow threads Sep 3, 2016
Plumbing Forum, Professional & DIY Advice Air chamber--drop elbow vs drop tee? Nov 3, 2012
Plumbing Forum, Professional & DIY Advice Best sealant for connection to in-wall drop ear elbow - Teflon tape or thread sealant Feb 7, 2011
Plumbing Forum, Professional & DIY Advice Securing 1/2" drop elbow Aug 18, 2009
Plumbing Forum, Professional & DIY Advice Stripped drop elbow HELP Jun 28, 2006
