Drip Sound When Bowl Level Increased
Carlos E.
Covina, CA
We just moved into a new home and when my upstairs toilet bowl water level rises due to either a #1 or #2 usage I hear a very slow dripping sound behind it. There's no sign of moisture accumulation anywhere. Any ideas on what's causing this.
I think you'll find that is normal for many toilets...my unprofessional opinion. Each toilet has a water level, that, if exceeded, water will fall over the trap and down the drain. Do it a little at a time, and as things slosh a little, you might notice it as a drip.
Jimbo
San Diego, CA
jad...is exactly correct. The bowl is filled to just the point where literally one more ounce of water will cause it so start overflowing the weir. Toilets and piping arrangements differ as to whether or not there will be a noticeable drip sound.
Carlos E.
Covina, CA
Thank you all for easing my mind about perhaps having some unseen water damage happening behind the walls. Just out of curiousity... Is there any way of adjusting the bowls water level so that there's a little allowance for additional fluids without having the overflow/drip starting?
Thanks again.
Carlos E.
Not normally. The tube that fills the bowl usually overfills it somewhat so that the level is right at the full point. That means that anything that is added makes it overflow.
