drip line setup
Discussion in 'Irrigation / Sprinkler Forum' started by scheetz83, Oct 1, 2006.
  1. scheetz83
    scheetz83 New Member
    Oct 1, 2006
    Hello
    I am new to this forum and I need a little help.
    I am setting up a drip irrigation system to irrigate about 30 new trees on two zones with zone 1 (drip)putting out 45gph and zone 2 (Microsprinklers) putting out 65gph. I am looking at using a pair of sprinkler valves with a lawn sprinkler timer. I am trying to do it cheap because with in the next few years the trees should be able to handle the selves
    My questions are:
    I understand that some valves will not work on a low flow application. what valve would work the best for me?
    I have about 3 rolls of this wire http://www.amazon.com/Works-30031-HFWBC50-Speaker-Burial/dp/B00016HY98
    that I was going to use but never did will it work for the sprinkler valve wiring? I will have to splice it twice as the controller is 110ft from the valves.
  2. jimbo
    jimbo Plumber
    That 16 gauge wire is more than adequate for your application.
    I also see no issues with flow on a zone valve. These valves are used all the time on drip sytems. If it is an anti-siphon type valve, pressure is what activates the diaphragm and the vacuum breaker poppet. Low flow should cause no problems.
    If you get your valves at a box store, Rainbird or Toro would be among the choices. Do NOT by the "homeowner" cheapie; you will have trouble with these. Expect to pay around $20 to $25 each.
    For the money, the RainJet and Orbit brands are OK.
  4. scheetz83
    Oct 1, 2006
    that's great to know
    I was at the local Home improvement store today and was looking at the valves they had orbits, Toro, rainbird, and lawn genie. Some had a min and max flow rate listed and some did not. I think I will go with the rainbirds as they where only $15. The Box said on flows of less then 3gpm I must install a RBY filter upstream.
    ``What is a RBY filler, is it special type of Y filter?
    ``I have a Rain drip Y filter installed at the beginning of the drip system. Is that what they are talking about?
    ``Also I have seen setup where there is for example 3 valves and each valve has a y filter just before it. Is that necisary?
    ``Wont 1 y filter on the main supply line to both valves do the trick.
    thanks
Similar Threads: drip line
Irrigation / Sprinkler Forum Drip Irrigation system often leaks at barb connections to mainline Jun 22, 2016
Irrigation / Sprinkler Forum Rain Bird drip line Aug 7, 2011
Irrigation / Sprinkler Forum Depth of poly? Depth of drip line? Jun 28, 2007
Irrigation / Sprinkler Forum Application of Drip irrigation pipe Oct 27, 2016
Irrigation / Sprinkler Forum What is Drip Irrigation? Jul 13, 2016
