Drip Legs On Gas Lines
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by toolaholic, Sep 29, 2005.
  1. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    here in sf we are forced to put in more drip legs than anywrere.
    this is there amendements in addition to the upc. in removing old ones i,ve yet to find debrea! what,s your thoughts on this please . thanks Tool
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    In my area the Gas/Utility company will tell you that their gas is so clean that you can 90 right into any appliance. Well that might be the case but it is what the gas runs through before it gets to your appliance is what can cause harm. I don't know how many times I have removed drip legs to spin a tee off for a gas water heater replacement and find oil buildup coming out of the bottom of drip leg. I can imagine what that oil would do to that fine screen in the gas valve. Let alone catch debri. Oil being the threading oil used on site to cut pipe and put it up. As far as debri though alone, I haven't seen many screens clogged either, the oil is what I would be worried about if I cut numerous cuts heading downwards toward the gas valve. Paper towels work good though if you stick them in the ends after cutting.
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    drip legs
    Also dust and dirt, dead insects and spider webs can migrate to the inside of pipe being stored and transported.
    [​IMG]
  5. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    one before each appliance, reasonable
    now add one after each change of direction
  6. plumguy
    plumguy New Member
    Jul 15, 2005
    MA
    Here it is called a "sediment trap" and must be installed on the inlet of all appliances except clothes dryers,ranges,outdoor grilles and illuminating appliances. They also cannot be installed outside in case they were to collect condensate and freeze. In all the ones I have removed I have never seen a spec of dirt or drop of water.
  7. dubldare
    dubldare Plumber/Gasfitter
    Sep 14, 2005
    Plumber/Gasfitter
    MN/ND
    In my neck of the woods drip legs have been required forever.
    Way back in the day, some of the underground gas mains in Minneapolis were hollowed-out wooden logs (1870's). Back then we didn't have natural gas, rather 'manufactured' gas from coal. Because of the wooden mains, water vapor was added to the gas to keep the wooden logs 'swelled'-wet gas.
    The wet gas was used until the mid 1930's, until natural gas pipelines were run.
    Back in the day, the drip leg was a necessity to catch water and crud, and it needed regular cleaning.
    Nowdays, drip legs are still required on all appliances.
    As far as what gets caught in them, I most often see thread oil and dirt.
  8. Kristi
    Kristi Tradesman Plumber
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    wow!! Sounds like wooden logs hallowed out for the city water main, lol!
    Tool, a dirt pocket for each change in direction??? That one sounds absurd EVEN for sf :), talk about taking the code too far... in my opinion
Similar Threads: Drip Legs
Plumbing Forum, Professional & DIY Advice Black pipe: unions & drip legs Feb 5, 2008
Plumbing Forum, Professional & DIY Advice Dripping faucet Jan 26, 2017
Plumbing Forum, Professional & DIY Advice American Standard Single Lever drip behind cartridge Dec 1, 2016
Plumbing Forum, Professional & DIY Advice Found a new drip. Causes? Oct 13, 2016
Plumbing Forum, Professional & DIY Advice delta single handle faucet drip Jan 3, 2016
