Drip irrigation of groundcover
Discussion in 'Irrigation / Sprinkler Forum' started by jdkimes, Jun 30, 2005.
  1. jdkimes
    jdkimes Engineer
    Engineer
    Littleton, CO
    Maybe more of a landscaping/gardening question:
    I live in Colorado and have quite a bit of xeriscape (low water landscaping) groundcover and use some dripping irrigation. But what's the best way to water a larger area of groundcover (6x25) with a drip system?
    I know there are a lot of drip pipes/tubes but should I just lay them on top of the ground cover? How far apart to lay them? or do I try to put the pipes on the ground?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Toro makes a 1/4" drip tube with 1/2 GPH emitters every 6" You could easliy snake this through the ground cover (under the canopy) in a pattern which would water adequately. It would not be visible if you work in in under.
  4. hj
    drip
    You can use the pipe with integral emitters, or use soaking hose in a serpentine pattern, or use the small spinning emitters.
Similar Threads: Drip irrigation
Irrigation / Sprinkler Forum Bury drip irrigation main connected to hose bib? Mar 4, 2017
Irrigation / Sprinkler Forum Application of Drip irrigation pipe Oct 27, 2016
Irrigation / Sprinkler Forum What is Drip Irrigation? Jul 13, 2016
Irrigation / Sprinkler Forum PVC Drip Irrigation System for your garden Jul 8, 2016
Irrigation / Sprinkler Forum Drip Irrigation system often leaks at barb connections to mainline Jun 22, 2016
