Drip Irrigation Help!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tsingh, Mar 30, 2013.
  1. tsingh
    tsingh New Member
    Mar 30, 2013
    hayward,ca
    I put together a drip irrigation system that looks as follows.
    1 - From a garden spigot => small lead hose => multi connector manifold => timer valve (attached to an orbit timer) => 20 psi pressure regulator => pvc adapter => hose connector => 1/2 inch drip irrigation hose => connector => 1/4 inch drip irrigation tubing => 1/2 gph red drip emitter.
    2 - The half inch tube runs around the garden as follow
    26 feet straight (part 1) => elbow connector => 5 feet (part 2) => 30 feet straight (part 3).
    3 - I have for 1/2 gph emitters towards the end of part 1 and one sprinkler type emitter towards the end of part 3.
    When I turn the system on (I have the spigot turned on only ust a little bit), either manually or automatically for 1 minute..the 4 1/2 gph emitters are spraying a stream of water instead of dripping.
    What am I doing wrong?
    Thanks
    Here is a picture of the system.
  2. hj
    YOU can't do anything "wrong" with a drip system. Either the emitters need to be adjusted or they are defective, or they are designed to emit a "stream" in order to deliver that gph.
  4. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    Are you using feed-through emitters, or end emitters?
  5. wallskev
    wallskev New Member
    May 14, 2009
    Manufacturing Consultant
    North Carolina,USA
  6. hj
    He has a flow control pressure regulator at the connection to the water line. The thing he DOESN'T have is a backflow preventer on the hose faucet, which is a universal requirement.
  7. tsingh
    tsingh New Member
    Mar 30, 2013
    hayward,ca
    Exactly the problem. THANK YOU!!
Similar Threads: Drip Irrigation
Plumbing Forum, Professional & DIY Advice Gas drip leg outside? Saturday at 7:30 AM
Plumbing Forum, Professional & DIY Advice Dripping faucet Jan 26, 2017
Plumbing Forum, Professional & DIY Advice American Standard Single Lever drip behind cartridge Dec 1, 2016
Plumbing Forum, Professional & DIY Advice Found a new drip. Causes? Oct 13, 2016
Plumbing Forum, Professional & DIY Advice delta single handle faucet drip Jan 3, 2016
