Drilling into Granite Countertops
Discussion in 'Remodel Forum & Blog' started by Katonah Medic, Dec 31, 2008.
  1. Katonah Medic
    Katonah Medic New Member
    Nov 5, 2008
    Katonah, NY
    Just replaced all appliances in the kitchen, and when installing a new under-the-counter dishwasher, the two tabs that secure the machine to the underside of the countertop does not line up to the old holes. This means I have to drill new holes to be able to use screws to secure the washer to the countertop.
    My tops are granite.
    Should/can I use a masonry bit to make pilot holes? I've seen granite cut with special wet blades.
    Do I need to keep the bit wet?
    Are there any special granite anchors? The old ones appear glued in.
    Thanks.
  2. jimbo
    jimbo Plumber
    Don't drill the granite, especially that close to the edge. Most dishwashers today come with alternate tabs, to secure to the side of the cabinet instead of the underside of the top.
  4. harleysilo
    harleysilo New Member
    May 26, 2006
    Georgia
    If you adjust the washer legs up all the way, how much clearence would you have between bottom of counter and top of washer? One could adhere a strip of cabinate material to be screwed into.
  5. maintenanceguy
    maintenanceguy In the Trades
    Aug 18, 2008
    Pennsylvania
    When stone countertops are installed, all joints are made with a 2-part expoxy. I'm sure a bracket fo some sort cold be fabricated easily and epoxied to the bottom of the countertop.
    I've never seen this done, just brainstorming.
  6. Katonah Medic
    Nov 5, 2008
    Katonah, NY
    I thought about using the existing holes to run a bracket/plate to each tab. That may have to be the way to go.
    I can't raise the washer any higher or the front door won't open.
    The tabs are recessed about two inches from the edge. Is that still to close to drill?
    I re-read the installation directions, and there are no other ways to secure the washer other than those tabs.
  7. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    call the installer
    as others have already stated...
    do not try to drill that granite, you will probably ruin it
    call the people that installed it and they can send someone out who
    knows what theyare doing and pay them to do it right.
    something else I have done in the past is taken a peice of
    1/2 x2 trim board the length of the dishwasher opening,
    painted it the color of the granite, then used clear silicone
    and glued it up across the front of the area
    then once it was set, I screwed the dishwasher into the wood...
    I had a fairley large gap to work with...
    it looked pretty good.. probably still there today
  8. harleysilo
    May 26, 2006
    Georgia
    Here are some poor quality low light pics of what a couple of us are talking about.....a strip of wood glued into place.
    Also when I wrote screw legs up that would increase the space between the top of washer and bottom of counter, just to be clear.
    Taken from 5' off the ground a few feet from washer (you don't see it)
    [​IMG]
    [​IMG]
    [​IMG]
  9. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    Here's another solution. I'll admit it's slightly ghetto. This also depends on how much space you have left above the dish washer. Take a blanket or other space taker like card board and place it on top of the dishwasher. crank the dishwasher up as high as it will go. The compression will hold it in place. That is how mine is installed and I don't have any troubles at all.
    Tom
  10. WV Hillbilly
    WV Hillbilly New Member
    Aug 1, 2008
    WV
    I watch HGTV quite a bit & granite countertops & stainless steel appliances are all the rage . I sometimes wonder how long it will be before those expensive countertops & appliances will become ( dated ) & get thrown out in favor of the new rage .
  11. harleysilo
    May 26, 2006
    Georgia
    This is nothing new. Trends come and go. I painted our Kitchen Harvest Gold. Looks great. My parents hate it, reminds them of many years ago. They have a toilet and tub that would match LOL.
  12. GabeS
    GabeS Remodel Contractor
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    If the granite craze dies down, then at least you still have a long lasting countertop.
Similar Threads: Drilling Granite
Remodel Forum & Blog Drilling through four 2x8s? Can it be done to run a drain line Nov 1, 2010
Remodel Forum & Blog Fixing dryer vent by drilling hole in a beam May 8, 2009
Remodel Forum & Blog Drilling concrete slab Jan 13, 2009
Remodel Forum & Blog Drilling thru Rock and Cement May 27, 2008
Remodel Forum & Blog Bumblebees drilling holes in my shop frame Apr 23, 2008
