drilling floor joists...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by coach606, Jun 23, 2006.
  1. coach606
    coach606 New Member
    Apr 25, 2006
    Illinois
    If you're going to be drilling floor joists, you pretty much need a right angle drill, don't you? Also, you have to use some extra caution, right as if the drill gets stuck it will spin the body and can hit you, right?
    My understanding is that I should drill a hole 1/4 inch bigger than the pipe and then maybe spray some foam insulation in the hole.
    Any comments or suggestions on drilling floor joists? I will stay within code.
  2. prashster
    prashster New Member
    Dec 7, 2005
    The code is based on the size of yr joists. You're limited in how close to the top and bottom and end you may drill. But, you have to check with your township office. Don't go by advice here on this. Once you drill, going back's a pain.
    Assuming your location is permissible, then I would drill slightly larger and foam insulate. The insulation will prevent bugs and heat loss and provide support and shock absorbtion between the pipe n joist.
  4. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Drills
    Yes, you'll probably need a right-angle drill. Yes, if the hole saw binds, the drill will spin and can do serious damage to you. With a right-angle drill, it's a little better, since you've got the longer arm of the drill to resist the drill's motion. The larger the hole, the bigger the problem. You have to use very light pressure on the hole saw and be careful to keep the axis of the saw perpendicular to the surface of the joist. If it's a multi-speed drill, I use the high-speed setting, since it delivers less torque, but will cut fine even with low pressure. As soon as the pilot drill breaks through, start cutting from the back side. Use a sharp hole saw. Wear gloves. Be patient. Good luck.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You can get a right-angle attachment for a regular drill. Harbor Freight among others have them and they are inexpensive. They are also very handy for that once-in-awhile-screw that is in an impossible location, so worth while having one. Otherwise, rent a right angle drill, they're too expensive to buy unless you are "in the business".
  6. tbplumbloco
    tbplumbloco New Member
    Jun 5, 2006
    drilling joists
    Use a RT angle drill and self- feeding bits.According to the IPC the rule that is used is 1/3rd the depth of the joist,example2x8 joist you can drill 2+3/8" It is done all the time in the real world as they say,the one joist that that you may have to drill for the 3" pipe you can brace and support that joist by boxing or heading it with framing lumber perpendicular to the hole ,that goe s for the smaller holes if you are concerned,also check out E-B.. they have excellant used tools,milwaukee rt.angle drill+ self-feeding bits,it may be worth the investmant,after this project is completed your services will be in demand.
  7. coach606
    coach606 New Member
    Apr 25, 2006
    Illinois
    Thanks everyone...
    I'm in good shape on the joists. Thanks everyone.
    I'm still waiting for the zoning variance, decision is coming next week. Shouldn't be a big thing, but you never know. So project is coming up in 2-3 weeks.
    Thanks to everyone's help I'm really feeling prepared. I was practicing sweating some pipes today and I've got the dwv plan all laid out. I'm looking forward to getting started.
    Thanks again.
Similar Threads: drilling floor
Plumbing Forum, Professional & DIY Advice Core Drilling and Floor Drain Question Aug 31, 2011
Plumbing Forum, Professional & DIY Advice Core drilling Apr 16, 2012
Plumbing Forum, Professional & DIY Advice Need Advice on preventing drilling into Water Lines - Grab Bar Installation... Aug 29, 2010
Plumbing Forum, Professional & DIY Advice Horizontal drilling/boring Jan 23, 2010
Plumbing Forum, Professional & DIY Advice Help drilling joist Dec 18, 2009
