drill point well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by newf, Feb 15, 2009.
  1. newf
    newf New Member
    Feb 15, 2009
    Greetings all
    I am trying to activate an old existing well for water at my cabin. The well opening is aprox 40 ft below my cabin. The well opening is 8 feet deep and 36 inch opening. the bottom is around the same elevation as a nearby pond 30 ft away. I have cleaned ot the well and used a submersible pump to pump the water.While pumping I located a drill point that was 4 ft long in the bottom .( I used a chainfile to pull it out as it was plugged from the top) Water coming in from a spring maintained about 5 inches above the drill point. I have a 2 stage deep well pump with a air/water tank that when I connected in before the frost i could pump water from the pond to my cabin. Any info as to how i should proceed to activate this existing well is appreciated. thanks I was thinking about driving a new well point in but i need info as to how do I know if it is deep enough? and if a foot valve is attached to the point or what way should i connect everything?
    Bernie
Similar Threads: drill point
Pumps and Tanks Well Forum & Blog. Water is life. Saved on the Well Drilling, Getting hammered on pump install,,,Need some input. Mar 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Drain back system for drilled well Mar 13, 2017
Pumps and Tanks Well Forum & Blog. Water is life. About to drill well - Need Advice Jun 29, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Drilled well issue Jun 2, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Continuing Education Hours for Drillers & Pump Installers (Online) Dec 7, 2015
