Drake water level - Plumbing 101
Discussion in 'Toilet Forum discussions' started by dmw04, Oct 29, 2004.
  1. dmw04
    dmw04 New Member
    Oct 29, 2004
    I installed the Drake toilet myself and the initial toilet/tank I had ended up having a leak between the tank and toilet. It was around the gasket/flush valve area. Problem must have been that hugh nut wasn't tightened enough. Anyway I returned the tank for another one and problem was solved. I had to scratch my head on the QA there. I noticed it was made in China...I thought they would be made in Japan or Georgia. Anyway...to my real issue/question.
    So, I got everything installed and I noticed the water level, upon filling would be at what I would expect to be the proper level. Then I hear a trickle trickle sound like water draining away. My water level dropps about 1/2" maybe up to 3/4" from its original fill. This occurs within 30 seconds of filling. No more water loss appears to occur.
    When setting the toilet I didn't concern myself with leveling. I recently checked it and here is what my level tells me:
    BACK ----- FRONT of toilet
    lower by about 1/4" (eyeball) plus or minus a 1/16"
    Thus water would tend to flow to back of toilet ever so slightly.
    So, my question is, if I lift up and back and level out the toilet (obviously disassembling everything and replacing the wax ring) would that solve the "trickle trickle" noise and the loss of 1/2" of water in the bowl?
    I'm sure someone has installed one of these toilets before and seen something similar. Sorry if a question like this has appeared before and I didn't see it.
    Thanks,
    -dan
  2. jimbo
    jimbo Plumber
    Not specifically familiar with the Toto, but with any toilet, level is important. If the back is low, then when the bowl refills water will slowly spill out over the trap weir until equilibrium is reached.
Similar Threads: Drake water
Toilet Forum discussions Toto Drake Water level questions Nov 8, 2016
Toilet Forum discussions Toto Drake and water softener Sep 30, 2016
Toilet Forum discussions Should water be coming out of Toto Drake Fill Valve? Apr 18, 2016
Toilet Forum discussions Water level in bowl drops after flushing - Toto Drake CST744SG Nov 22, 2015
Toilet Forum discussions Toto Entrada vs Drake1 water spot and bowl wash Oct 19, 2015
