Drake Parts
Discussion in 'Toilet Forum discussions' started by noeffort, Apr 23, 2011.
  1. noeffort
    noeffort New Member
    Feb 9, 2008
    70.134.226.124
    I have a leak from the bolts holding the tank to the base and would like to replace the rubber washers. Do I have to use the Toto parts or can I go to a plumbing supply house for replacements.
  2. jadnashua
    Any rubber washers designed for use in a toilet should be okay. If they leak, two things: first, sometimes it helps if you lightly sand any roughness off of the casting before installing (only takes a few seconds), and second, you may not have the washer in the right place. Inside the tank, there is no washer, just the rubber and the bolt head. Washer on the outside and the nut. If the tank is not cinched down so it is (almost) touching the bowl, it could leak while flexing.
  4. noeffort
    noeffort New Member
    Feb 9, 2008
    70.134.226.124
    Thanks Jim,
    I just got back from the plumbing supply house before I saw your post. I got a hardware kit and tank to bowl gasket.
    I had a problem installing the new gasket, I couldn't get a good three point contact, I installed the original and no problem. The replacement gasket I got was larger and didn't have a lip on it.
    The hardware kit I picked up had 4 rubber washers and 4 metal washers. I installed a rubber washer on the inside and outside against the ceramic with a metal washer on top of each one. It gave me a really good sung fit, better than before.
    I told my 3 daughters the toto is ready for action!!!!
    Thanks for the help!
Similar Threads: Drake Parts
Toilet Forum discussions The very first TOTO Drake tank and it's parts May 24, 2014
Toilet Forum discussions TOTO Drake parts May 1, 2013
Toilet Forum discussions Drake II 1G Parts List Out -- Complicated! Sep 18, 2012
Toilet Forum discussions Drake parts Jul 8, 2010
Toilet Forum discussions Toto Drake parts question Jan 5, 2007
