Drake Differences & 11" rough-in Qs
Discussion in 'Toilet Forum discussions' started by TG284, Mar 12, 2012.
  1. TG284
    TG284 New Member
    Mar 12, 2012
    Illinois
    After a lot of reading here, it looks like the Drake is probably my best option for compact size & my 11" rough-in requirement.
    Are all drake cst743 round models created equally (newer, older, Eco 1.2, 1.6)? So if I buy from somewhere with older stock or the latest batch, does the 11 to 10 7/8" rear clearance likely still apply? Ive found a few spec sheets with different rear #s, just want to confirm.
    Might any of the Aquia models or newer contemporary looking/smaller tank units work with the 11"?
    Thanks Guys
  2. re8
    re8 New Member
    Mar 12, 2012
    Philadelphia
    More on Drake and 11" rough-in
    I've seen on this forum that the Toto Drake can make do with a 10-7/8 rough in.
    So does that mean that if I measure 11" from the wall to the bolts of my current toilet, then I'll have only 1/8 of an inch to spare?
    If so, I better make sure my measurements are accurate!
  4. Terry
    Aug 17, 2004
    At 11" you only have an 1/8" to spare.
    The horn is 2-5/8" going into a 3" drain. There is some room to fudge a bit at that point. But......you won't know for sure what you have until the bowl is pulled.
    The Aquia fits at 11.5", but also can be ordered with a 10" bowl CT412MF.10 that works at 9.5"
    The Drake CST744EF.10 works at 9.25" too.
    [​IMG]
  5. TG284
    TG284 New Member
    Mar 12, 2012
    Illinois
    Thanks Terry & All, after finalizing tile im now working with ~10.5"... So 10" rough in it will be
    Am I correct in finding that the Drake 10" is NOT offered in round, only elongated? Any other shallower depth 10" toilets that i've overlooked?
    I am a click away from ordering the Aquia 10" (CST412MF.10), I like the narrow tank and even though it is elongated, a 27.5" depth. Any other significantly shallower toilets, or ones that tuck the wall best for 10.5"RI that come to mind, lmk.
    Thanks again!
Similar Threads: Drake Differences
Toilet Forum discussions Differences between Toto Drakes CST744EL#01 and CST454CEFG#01? Apr 8, 2015
Toilet Forum discussions Toto Drake Round, Elongated, ADA MaP Testing Differences Oct 15, 2013
Toilet Forum discussions toto drake tank differences Jun 6, 2013
Toilet Forum discussions Does the Toto Drake have the same water spot as the Gwyneth? What are the differences Jul 3, 2010
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
