Drains & Vents in studio addition
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by AKAJIMSTER, Dec 12, 2009.
  1. AKAJIMSTER
    AKAJIMSTER New Member
    Dec 12, 2009
    Ventura County, CA
    I am adding plumbing to a room above our garage and laundry room to be able to rent out as a one room studio. The main lines & branches have already been run by a handyman/plumber friend of a friend and I've got a few concerns about the layout and whether or not I'll have problems with the venting or who knows what else. I know I definitely need to add a cleanout; don't know where the best spot for that would be either. Forget about asking the inspector to have it inspected; I tried the legal route first(getting a permit). Every time I went down to the city to double check requirements, etc., the price went up as did the requirements, which had nothing to do with the plumbing. I've attempted a diagram and looking for feedback and suggestions for improvement. Thanks in advance.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
  4. psjr56
    psjr56 Member
    Apr 23, 2009
    S. Jersey
    Is the shower the wet vent? Could the a vent for the shower be tied with the others in the attic? I guess the toilet should have a vent too huh?
  5. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    The shower and the toilet are wet vented.
    Wet venting is allowed here but you cannot have a non-bathroom fixture in the middle of a bathroom wet vent. That requirement is based on IPC.
  6. jimbo
    jimbo Plumber
    San Diego, CA
    The vent across from the kitchen seems to be a horizontal vent below the flood rim of the fixtures. That would be your biggest no-no . Unless the redbox is saying that the pipe goes vertical to about 42" before going horizontal
  7. hj
    permit
    quote; Every time I went down to the city to double check requirements, etc., the price went up as did the requirements, which had nothing to do with the plumbing.
    You sound just like the guys on "Dream house", when they added an addition to their house. When the inspector came out he told them the addition was too close to the property line, they had to move it. They KNEW it had to be 4', but just ASSUMED that the fence was 18" on their side of the line. When they had to move the foundation, they said that they, also, would not get permits for any other work. I guess it is okay to do something "illegal" as long as nobody sees it or catches you doing it. THOSE "requirements" were probably to make sure what you were doing would comply with city requirements. IF so, and one of those requirements was "NO rental apartments in a residential area", you will discover it as soon as one of your neighbors reports it.
  8. AKAJIMSTER
    Dec 12, 2009
    Ventura County, CA
    Dunbar - Wet plumbing is allowed here - if done correctly. That's what I wanted to know, whether or not it was done correctly or not.
    psjr56 - The vent stack is at the bath sink; the shower and toilet are wet vented from that and the sink in the kitchenette will have a vent going up into the attic and tie in horizontally to the bath sink vent. I don't have enough room at the roof line in the attic to put in the vent lines for the shower and toilet in the wall behind them. What "non-bathroom fixture in the middle of a bathroom wet vent" were you referring to? My city goes by the UPC, if that matters.
    jimbo - Yes, both vents go vertical up into the attic.
    hj - I think I saw that episode!
    The code does allow 2nd units. The city wanted me to go to the expense of hiring an architect to do a complete plot plan showing landscaping, existing layout, etc., etc. I explained to them that the structure already exists(they would not accept pictures accompanied by a detailed & accurate sketchup from a home design program) and nothing on the exterior of the property would change; it would only be the addition of plumbing and other fixtures in the interior of an existing structure. They also wanted me to install a carport in front of my garage along with other misc BS. So, it went from $750 in permits and "no problem" to over $2,500 in permits and at least $4-5,000 in additional work - before I spent anything on the plumbing and other improvements/fixtures on the interior. :eek: That being said, the jackhammering has already been done(took most of a day) with no complaints! The neighbors on my left and right already know what's going on and have no problems with it-one also has a studio they rent out(permitted years ago before the additional requirements). If I do get complaints and the city comes out to have a peek, I just want to make sure the guts are done correctly so there will be no problems with that. I'll worry about the rest if it becomes a problem. So, any wisdom on the plumbing layout?
  9. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    The kitchen sink. Under IPC I think it would be under 909.1 but I don't have access to UPC. It's not something that wouldn't work anyway, just one of those code issues thing. I think it came in around '01.
  10. AKAJIMSTER
    Dec 12, 2009
    Ventura County, CA
    Thanks for the replies. Any others? Does it look like it will work? Any problems?
  11. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    That seems odd. This would make venting some bathrooms basically impossible without flat dry vents below the FLR of the fixture they serve.
  12. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    UPC did not allow wet venting for many years. I never found a house that I couldn't plumb without running a flat vent. it just takes some extra planning and of course, pipe.
  13. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    Well, I know we can't run flat vents but we can use wet vents if sized properly. It looks like you have both. It does not look like the toilet is vented to me. The vent should come off between the closet bend and the drain wye going into that line.
  14. AKAJIMSTER
    Dec 12, 2009
    Ventura County, CA
    dce - What is a flat vent? I was planning to add another wye with a cleanout between the closet bend and other wye. Would the wet vent I have at the lav be sufficient for the toilet or do I definitely need a separate vent for the toilet where you suggested? If I do need one, where would the best place be for the cleanout if this spot is taken? Could I put another wye off of the one I add for this vent? Thanks.
  15. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    1) A flat vent is a vent which runs horizontally (less than 45 degrees) while it is lower than 6" above the flood rim of the fixture it is serving. In other words; a vent must have a vertical slope (greater than 45 degrees) until it reaches 6" above the fixture it is serving. Then it can run horizontally.
    2) Clean out: Replace the 3x2 wye with a 3" wye; then use a 3x2 wye for the kitchen sink and a 3x2 wye for the shower/lavy drain; put the clean out at the end of the second 3x2 wye.
    Hope that helps.
  16. AKAJIMSTER
    Dec 12, 2009
    Ventura County, CA
    No flat vents here. The vent from the kitchen sink will run vertically up into the attic, then horizontally over to the vent from the lav, then out the roof. (All the items boxed in red are vertical).
    That's what I was thinking after reading your other post. Thanks!
Similar Threads: Drains Vents
Plumbing Forum, Professional & DIY Advice Do drains leading into lift pump need vents and traps Jul 28, 2016
Plumbing Forum, Professional & DIY Advice Water Softener and Sink drains and vents Jan 26, 2016
Plumbing Forum, Professional & DIY Advice New Basement Drains and Vents Jun 19, 2014
Plumbing Forum, Professional & DIY Advice Help with planning drains/vents (air admittance valves) for bathroom shower addition Aug 13, 2013
Plumbing Forum, Professional & DIY Advice New Drains/Vents routing. . . May 4, 2013
