Drainfield restoration
Discussion in 'Toilet Forum discussions' started by MarkK, Feb 17, 2013.
  1. MarkK
    MarkK New Member
    Feb 17, 2013
    FL
    I tried searching the forum before posting this and couldn't seem to find an answer so if I overlooked it, I do apologise. What's the professional experience consensus on attempts at restoring a slow drainfield via pumping/pressure blasting? I've read all the sales pitches about different chemical/bio treatments and although I have no personal experience with them, I'm very skeptical of the claims. Thanks, Mark
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    First you need to determine why the drainfield is slow. If the problem is high groundwater, nothing short of elevating the field or lowering the water table will help.
    Around here, fields that once worked but then clogged up over time simply get a new elevated field installed. IMHO, they look terrible having a giant mound in your yard.
    The codes changed here. At one time the field could be flush with the surrounding grade but now one can only go down 2 feet and so need to go up 3 feet.
  4. MarkK
    MarkK New Member
    Feb 17, 2013
    FL
    Sorry, should have included a bit more info. It's an elevated installation, gravel trenches & sand, 4" Tee split from the tank, no D-box and most likely slow because the home owner was adding Rid-X which looks to created a lot of floaties.
