Drainage Industries 2" in-line check valve
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by PaulGray, May 10, 2006.
  1. PaulGray
    PaulGray New Member
    May 10, 2006
    I am replacing my existing sump pump with a sewage pump (I need the greater pumping capacity). Although the pump will be processing ground water (no waste) I want to install the check valve horizontally. That way, if it picks up a piece of gravel or something it will not jam the valve.
    My question is, can I install a Drainage Industries (DI) 2" full flow in-line check valve horizontally? The current valve is installed vertically. I bought the valve from ******* & it did not come with any info.
  2. hj
    valve
    A piece of gravel should not jam the valve no matter what its orientation is. But since it is full flow, it must be a swing type check valve, and if so, then it can be horizontal as long as the hinge is on the top.
  4. PaulGray
    PaulGray New Member
    May 10, 2006
    Great, I appreciate the response. It is indeed a swing type check valve. The manufacturer of the sewage pump recommends a horizontal installation, so I will go with that orientation and ensure that the hinge is on top.
  5. PaulGray
    PaulGray New Member
    May 10, 2006
    Free flow vs. Full flow check valve
    One quick followup question. Is there a difference between a free flow check valve and a full flow check valve. My installation instructions call for a free flow valve - I am assuming I can use a full flow in-line check valve?
Similar Threads: Drainage Industries
Pumps and Tanks Well Forum & Blog. Water is life. Sump drainage pipe broken at foundation. Jul 10, 2013
Pumps and Tanks Well Forum & Blog. Water is life. upwards laundry room drainage Jan 19, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Sump pump and Rain down spout drainage. Jul 5, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Drain Red Light going off on Geothermal - suspect blown drainage pump Sep 24, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump / Drainage System Problem Dec 19, 2008
