Drainage for the washer is continually overflowing...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jeremy2323, Jun 28, 2006.
  1. jeremy2323
    jeremy2323 New Member
    Jun 28, 2006
    Teacher
    Texas
    Howdy!! New to this forum and I am excited about getting advice. My first problem is this:
    When we run the washing machine, we have to stop it during two cycles because water will start overflowing the drain pipe. It gurggles and seems to be putting out more water than the pipe (2 inch) can handle. We've tried liquid plumber, foaming pipe snake, the real pipe snake (both at the wall and in the yard at the cleaning plug), enzymes to remove sediments, and nothing seems to be working. I feel like it is a venting problem and gasses are getting trapped. If that's it, is there anyway to fix it without major remodeling? I don't even know if it currently has a vent.
  2. norcal1
    norcal1 Plumber/Owner
    Jan 24, 2005
    Look on the roof, above the washing machine drain, for a vent. Run your auger/snake thru that.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    How old is your home?
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    My 40 yr old house had only a 1 1/2" pipe for the washer, and it was overflowing with the new machines. The solution was to run the hose to a deep laundry sink adjacent to the washing machine. The sink buffered the flow and there is no problem.
    You need to be sure that the sink is clear when the washer is used. I put a note on the washing machine to check the sink before starting.
Similar Threads: Drainage washer
Plumbing Forum, Professional & DIY Advice Drainage for two sinks and two dishwashers Jan 5, 2016
Plumbing Forum, Professional & DIY Advice Drainage pipe behind dishwasher Oct 13, 2015
Plumbing Forum, Professional & DIY Advice Dishwasher drainage mystery Jun 15, 2015
Plumbing Forum, Professional & DIY Advice Dishwasher Hose Extension - Drainage Problems Dec 30, 2014
Plumbing Forum, Professional & DIY Advice Options for Washer drainage Jan 11, 2014
