Drain Volume
Discussion in 'Shower & Bathtub Forum & Blog' started by Hammy, Dec 7, 2011.
  1. Hammy
    Hammy In the Trades
    Dec 7, 2011
    Kitchen & Bath Makeovers
    Middle TN
    We are installing body sprays in a shower and I am concerned about the drain capacity. The shower control valve can supply 9 gpm @ 90 psi. The city reports the supply is normally at 65 to 80 psi static pressure. Drain is a 2" pvc line assuming properly installed.
    Hammy
  2. jadnashua
    One drain at 2" should be able to handle it - just don't stand on the drain cover for long! My tub drain is 1.5", and on full-blast, the tub drains faster than the incoming water...a 2" drain is a lot bigger in area/volume. If you're really worried, they do make 3" drains, or you could put two 2" ones in or a linear drain, but ensure the underneath plumbing is big enough, otherwise, it won't make any difference.
Similar Threads: Drain Volume
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Today at 10:06 AM
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Tuesday at 11:03 AM
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
