Drain Spout
Discussion in 'Shower & Bathtub Forum & Blog' started by Antigone, Feb 2, 2012.
  1. Antigone
    Antigone New Member
    Feb 2, 2012
    Damascus, MD
    I just finished tiling my bathroom shower/tub. Unfortunately, I just realized that I made the hole a little wider than my drain spout. So, when I screw the spout on there are places that the tile does not even reach the spout. Since I cut the hole a little too much, I am not able to put a piece of tile to cover the "spaces/holes" up. I really want to avoid caulking, so if anyone else has another idea that would be very helpful.
    Thanks....
  2. Terry
    Aug 17, 2004
    You may be able to use an plate or escutcheon behind the spout.
  4. jadnashua
    While it's a pain, if you have some extra tile(s), you can remove the grout around the bad one(s), then break the tile, and then install new one(s) so that it will cover the hole. As an alternative, you may be able to find a tub spout that has a larger footprint, or try to find an eschution plate you can live with.
Similar Threads: Drain Spout
Shower & Bathtub Forum & Blog How does shower line drain through tub spout when valve is off and diverter is set to tub? Apr 3, 2016
Shower & Bathtub Forum & Blog Stuck Tub Spout & Drain Flange Oct 20, 2011
Shower & Bathtub Forum & Blog Removing tub spout and drain Mar 8, 2005
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Monday at 10:06 AM
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
