Krooser78
Hello, I have some concerns with my bathtub and found this forum while searching for answers. Maybe someone here can help?
Problem is this: I have a recessed fiberglass garden tub that doesn't drain completely. Instead, a few cups of water remain toward the center of the tub. I have noticed that the skirt of the tub bows or bulges out slightly toward the center/bottom. In addition, the drain itself seems to be tilted or slanted with the edge of the drain closest to the rear of the tub 1/8" or more higher than the tub bottom.
The tub is about seven years old though it has been used rarely. I only noticed this after I replaced the Moen positemp cartridge. I don't think that would be a factor, but thought it worth mentioning.
So I guess I'm wondering if A. This is something I should be concerned about and B. Can it likely be repaired?
There is a stand up shower on the other side of the wall from the tub so the plumbing is not going to be easily accessible.
Thanks so much!
Josh
Thanks so much!
Josh
