Drain question: new utility sink + washing machine drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by brownetowne, Jun 26, 2011.
  1. brownetowne
    brownetowne New Member
    Jun 26, 2011
    madison, WI
    I am replacing a utility sink in my basement near the washer / dryer. The old setup had the washer drain line empty into the utility sink basin. As part of the project, I would like to plumb the washer drain directly into the plumbing. Two questions:
    1. *What's my best drain option for both the utility sink and the washer?
    2. *Something I liked about draining into the sink was the additional lint catch wire mesh sock that I could dispose of 2-3 times per year. If I plumb into the line, is there something that would allow an interchangeable lint filter?
    The existing setup is fairly simple —*a single trap that drains into a main stack. I'd upload the photo, but I seem to be having problems with that feature of this forum...
  2. jimbo
    jimbo Plumber
    The sink may be connected to a 1½" drain line. This is not adequate for a washing machine directly draining, and is not up to most codes
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    There challenges are that the washer will require a 2" drain and the traps from the washer and sink must be vented through the roof.
    Assuming you will need to run a new drain line into the building sewer, you will need to get a plumbing permit from the city and have the work inspected by the local plumbing inspector when it is ready.
    You can post a photo it's easiest to have it hosted on another web site and use their url.
  5. brownetowne
    Jun 26, 2011
    madison, WI
    Plumbing in basement
  6. brownetowne
    Jun 26, 2011
    madison, WI
    thanks all for the replies.
    this is the current setup.
    I know I need to install new valves for the utility, but I have no idea where to start on the washer drain —*can it just be an addition to the sink drain after the trap?
    thanks!
  7. Terry
    Aug 17, 2004
    It would look something like this
    [​IMG]
  8. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Terry's is a perfect example of how it can be done.
    Luckily, it appears that you have an existing vent.
    You must have a separate sanitary tee in the drain stack for each of the 2 fixtures, with the sink tee directly above the laundry tee.
    The sink and the laundry standpipe must each have their own individual trap.
  9. plumber2011
    plumber2011 Expert Plumber
    Jun 4, 2011
    Licensed master plumber and owner of small residen
    Boston, Massachusetts
    Brownetowne,
    Is there a kitchen sink above this? If so, check and see if the kitchen sink drains into the pipe going to the sink drain in the basement. If so, let us know as that will change our recommendations a bit, OK?
    Back to you...
  10. brownetowne
    Jun 26, 2011
    madison, WI
    Thanks for the recommendations, all.
    I made some headway last night after realizing I should re-route the water lines to one side of the basement window. Not ready to post and show quite yet, because that phase of the project isn't done yet.
    More to come tonight though.
    I'll post a picture with my idea of what needs to go where.
  11. plumber2011
    Jun 4, 2011
    Hi Brownetowne...
    You didn't answer my question about your kitchen drain? Please let us know if the kitchen sink from above drains into the cast iron drain pipe serving the basement sink, OK?
    Back to you...
  12. Multibeast
    Multibeast New Member
    Jul 16, 2012
    Madison, WI
    Can someone explain if there is any specific height to where the washer drain vent connects to the main vertical vent in this photo (near all the blue outlet boxes)? I am building a half-wall laundry area and would like to keep the wall as low as possible, hence hiding the connection in the wall. Thanks
  13. jadnashua
    By code, if I'm understanding your question, the re-vent must be 42" or 6" above the flood plane, whichever is higher. The flood plane would be the top of the stand pipe, since if there was a clog below, it could rise to the top of that. Also note, that once a vent, always a vent, or once a drain, always a drain. IOW, you can't vent into a drain unless you re-vent it properly.
  14. outdoorguy25
    outdoorguy25 New Member
    Aug 10, 2012
    Lakeville, WI
    Washer Wall box
    I know this is a somewhat of an older topic, but is there a code requirement for how far up the wall box has to be? I've got a window at 40.5 and I was hoping to attach the wall box under the window.
  15. jadnashua
    There is a code requirement on the min/max length of the standpipe (the vertical above the trap). Then, you have the depth of the trap, which is really your limiting factor (well, you have to have enough room to install the sanitary T on the drain line, too). I don't remember the exact numbers (and it may change based on which set of codes you use where you live).
  16. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    ive installed this setup, and the wife doesn't like the way it looks so, she would like it all hidden behind the washer. my question is how low can i put the box and standpipe so the operation is still correct? it's about 43 inches up now.i would like it at about 30 inches or so. thanks
Similar Threads: Drain question
Plumbing Forum, Professional & DIY Advice Quick kitchen sink drain and vent question Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Drain waste vent run new bathroom question Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Liquid Fire drain cleaner question Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Laundry Sink Drainage/Vent Question Dec 18, 2016
