Drain Problem: Replacing tub with 3 piece shower
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by LUFE37, Aug 22, 2006.
  1. LUFE37
    LUFE37 New Member
    Aug 22, 2006
    Have removed tub from bathroom and want to replace with a 3 piece shower. Shower drain is in center and tub drain is on one end. The floor is cement slab. How do I hook up the drain so that it is in the center and what size drain pipe do I need to use and can I use PVC pipe? If not what is recommended? Appreciate any help given. Thanks.
    Member Since
    08/22/2006
    Total Contributions
  2. Lancaster
    Lancaster New Member
    Nov 7, 2005
    2 inch pipe is required.PVC is fine for drainage.You will need to bust up the cement floor to relocate the drain.
  4. LUFE37
    LUFE37 New Member
    Aug 22, 2006
    TO LANCASTER: Thank you for your info.
  5. Lancaster
    Nov 7, 2005
    You're most welcome.
Similar Threads: Drain Problem
Plumbing Forum, Professional & DIY Advice Stone vessel sink drain problem Dec 2, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher draining problem! Nov 5, 2016
Plumbing Forum, Professional & DIY Advice Problem with draining dishwasher Feb 28, 2016
Plumbing Forum, Professional & DIY Advice PLZ HELP-kitchen drain connection problem Jan 15, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher Drain Hose Problem Sep 30, 2015
