Drain problem in jetted tub/shower.
Discussion in 'Shower & Bathtub Forum & Blog' started by CMWill46, Oct 2, 2009.
  1. CMWill46
    CMWill46 New Member
    Sep 7, 2009
    Dayton, Ohio
    I have done a complete remodel and put in a jetted tub and shower. The drain works fine with no leaks when shower is on, but when tub is filled up and then drained it leaks in the drain pipe in the crawlspace. The drain is 1 1/2 pvc. Any suggestions?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    When you drain a tub full of water the drain may be under minor pressure and has more water in it than when you are just taking a shower...find where the leak is coming from and fix it...
Similar Threads: Drain problem
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Ran into a small problem replacing drain. Mar 5, 2016
Shower & Bathtub Forum & Blog Bathtub Drain problem Aug 2, 2014
Shower & Bathtub Forum & Blog Bathtub Drain Problems Jul 8, 2014
Shower & Bathtub Forum & Blog Removing Shower Drain Problem Mar 16, 2013
