Drain pipes need replacing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Bassman, Jul 15, 2010.
  1. Bassman
    Bassman DIY Member
    Aug 25, 2006
    musician
    Ventura, CA
    I've been having problems with my drain system forever. The reason is that the grey water in my house doesn't run downhill like it should. In this photo you'll see what I have. For this run to be level, the cleanout end would need to come up at least half an inch. I'm thinking the entire thing has to be replaced with PVC. I understand how to connect to the vertical drains, using clamp connectors. What I need an opinion on is how to connect to the hub on the drain stack. I've read you can clean out the leaded joint and connect PVC to it, or cut just behind the hub and join there. This whole thing is about 4 feet long and it's 2" pipe. Thanks.
    [​IMG]
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Check your visitors message board for help !
Similar Threads: Drain pipes
Plumbing Forum, Professional & DIY Advice Updating laundry plumbing - vent and drain pipes Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Replacing sump pump basin...drain pipes are in the way. Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Raising sink drain pipes to fit new vanity plumbing area Jun 30, 2016
Plumbing Forum, Professional & DIY Advice Is it illegal or bad practice to join 2 drain pipes......... Jun 14, 2016
Plumbing Forum, Professional & DIY Advice Grease in plastic drain pipes - prevention Mar 2, 2016
