Drain line: Video inspection service
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rfsmith48, Nov 13, 2008.
  1. rfsmith48
    rfsmith48 Member
    Feb 23, 2008
    Colorado
    HI folks,
    I am about to Roto-root the Main drain for my house. I have been doing this annually due to sporadic blockages that always seen to occur when I am traveling. The annual cleaning seems to have eliminated the surprises.
    Questions: When I contract with a Video inspection service, what am I looking for?
    1. How do they trace the restriction/blockage? Do they use sensors to show the exact dig location on the surface?
    2. What kind of output should I demand/expect? VHS tape? CD?
    3. What else?
    Thanks in advance.
    Rog Smith
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Most will use a locating device such as Rigids Sonde to pinpoint location and depth. You will probably pay extra for this service above the cost of the camera inspection. We either let you watch as we go or if you want a copy we can send it to DVD so's you and the family can watch.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    After the line has been cleaned it when you want the camera inspection to go in and see any defect in the pipes. Once a year is a bit often and sounds like some repair is needed.
    THe camera has a transmitter built into it that can locate the bad spot with remarkable precision.
    I would recommend witnessing the inspection as there are companies that need to be kept on a close eye out there. A few but it is best to witness. There really is no rocket science here and anything they show you should make sense. All of the customers can readily tell when there is a problem. sometimes it takes a trained eye to know exactly what it is but they know something is wrong.
  5. hj
    video
    NEVER get a camera inspection without a tape or DVD. Without that you have to rely on the operator's opinion and memory, and that can be flawed. I just had one last week where the operator told the customer he had a broken sewer, roots in the line, and dips. When I did my own camera work, there were dips, but no break and no roots. If the first guy had given a DVD, I would have been able to check his opinion without the cost of a second inspection. But he wanted to break the exposed aggregate driveway and repair the sewer.
Similar Threads: Drain line
Plumbing Forum, Professional & DIY Advice Reverse Osmosis Drain Line Installation Jan 8, 2017
Plumbing Forum, Professional & DIY Advice Drain Line Repair in Crawlspace - am I being over quoted? Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Extending cast iron drain line for pedestal sink Nov 25, 2016
Plumbing Forum, Professional & DIY Advice Converting septic line cleanout (diagram\pic) for drain use Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Tub P Trap Lower than drain line Nov 1, 2016
