Drain line on a Fleck 7000SXT w/ 5gpm DLFC...
Discussion in 'Water Softener Forum, Questions and Answers' started by jkats, Jun 3, 2013.
  1. jkats
    jkats New Member
    Mar 3, 2013
    Oxnard, California
    Hi guys. I'm currently installing a couple of water softeners with Fleck 7000 SXT valves and 3.0 cubic ft of resin (14"x65" tanks). I was advised to use 3/4" pvc for the drain lines since they use a larger DLFC (the button says "500"). However, in one of the installs, the builders of the house supplied a "drain" next to the softener loop, and it's a 1/2" copper pipe. It's a finished garage, with no other drains around that I can see, so I'd rather not have to hack into the walls. Will using this 1/2" drain cause a problem with this size softener?
  2. ditttohead
    Jan 9, 2012
    Ontario California
    You will be just fine. The 5 GPM is under the 8-10 FPS for 1/2" copper pipe. Larger diameter drain lines on softeners can often times reduce the systems noise slightly.
  4. jkats
    jkats New Member
    Mar 3, 2013
    Oxnard, California
    cool - thanks dittohead!
Similar Threads: Drain line
Water Softener Forum, Questions and Answers Softener drain lines Jan 2, 2017
Water Softener Forum, Questions and Answers Water softener drain line tied directly into sewer line Aug 7, 2016
Water Softener Forum, Questions and Answers Aqua Pure CBF100 carbon filter Clack drain line leak Feb 18, 2016
Water Softener Forum, Questions and Answers Fleck Drain Line Mar 17, 2015
Water Softener Forum, Questions and Answers Fleck 5600SXT Drain Line Too Much Water? Mar 13, 2015
