Drain length and hot water in toilet?
Discussion in 'Shower & Bathtub Forum & Blog' started by paulhar, May 11, 2006.
  1. paulhar
    paulhar New Member
    Apr 19, 2006
    I have two questions:
    1) I have a 2†tub drain that runs 6.5 feet into a 3†wye from a toilet. The two descend at 45 degrees, 18 inches to the stack.
    Since I gone up one size from a 1.5 " tub drain, am I allowed longer than 60 inches for this drain?
    2 – My local bath supplier has sold me 2- ¾ inch shut off valves in order to connect the water supply to a ½ tub spout. The reason for this is that we want to use the same trim handles as the rest of the bathroom and we don’t want to use a shower valve for our wall mount tub spout (ugly). We have the plumber’s opinion that this cannot be done. That if we flush the toilet we can end up with back flow of hot water into the toilet. Our local bath shop that sold the valve – says that this cannot happen and that before modern mixers existed that this is the way all bath tubs were connected.
    Can I hook it up without backflow protection in the valve??
  2. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    I think so, but someone else will definately know.
    I don't see why this would be a problem. You're connecting your supplies to a shutoff and then joining together for the tub spout. Isn't that how old sinks were installed back in the day too? If your tub spout hangs down below the water level, that could be a problem.
    Maybe if you put yuor toe in the tub spout while it's filling w/ hot and cold running and someone flushes the toilet you COULD get some mixing, but that's hightly unlikely. Ever see that I Love Lucy episode where she gets her toe stuck in the Hotel's Tub's Spout? :p
    Jason
  4. Terry
    Aug 17, 2004
    UPC plumbing codes allows 60" for a 2" trap arm
    And 42" for a 1.5" trap arm.
    If the tub has a shower with it, it needs to be pressure balanced, they do sell seperate balancing units to work with two handles.
    If it's a tub only, then the two handles will be fine.
Similar Threads: Drain length
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Monday at 10:06 AM
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
