Drain help for new acrylic shower install
Discussion in 'Shower & Bathtub Forum & Blog' started by Amoreena, Dec 8, 2004.
  1. Amoreena
    Amoreena New Member
    Dec 8, 2004
    Hi! I've just removed my old leaking tile shower and want to replace it with an acrylic shower unit. Can anyone tell me what type of drain I have left here, and what to remove/how to connect a drain for an acrylic unit to it? I'm on a concrete slab, and I think this drain is cast iron, as the house is about 30 years old. Thanks, Amoreena
  2. hj
    drain
    It is hard to tell with the mortar still attached to the drain fitting, but it appears to be a cast iron unit. That has little relationship to the type of pipe, however. It is either screwed onto the riser pipe, or attached to it with a lead, or rubber joint. We cannot tell which of the above applies to you or the best way to remove it since each type of pipe and attachment requires a different method.
Similar Threads: Drain help
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Help removing a brass shower drain Jan 4, 2017
Shower & Bathtub Forum & Blog Remodeling Shower - Need help with shower drain Dec 2, 2016
Shower & Bathtub Forum & Blog Help identify mystery tub drain shoe sealant/gasket Jul 29, 2016
Shower & Bathtub Forum & Blog Stone bathtub drain help needed Jul 7, 2016
