drain help connecting p-trap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by annagibs, Sep 30, 2013.
  1. annagibs
    annagibs New Member
    Sep 30, 2013
    Cleveland
    I have 1 1/2" collars, I need help attaching the p-traps. What needs glued in the 1 1/2" collars to attach the p-traps? [​IMG]
    [​IMG]
  2. Terry
    Aug 17, 2004
    You would need a trap apapter.
    Either a standard female to trap, or a spigot to trap. The trap side would be a slip joint nut and washer.
    The other side would be a solvent weld (glued) fitting.
  4. annagibs
    annagibs New Member
    Sep 30, 2013
    Cleveland
    Thank you Terry!
  5. hj
    Is this question about two different sinks, because one photo shows an elbow and the other one a T?
  6. annagibs
    annagibs New Member
    Sep 30, 2013
    Cleveland
    Yes two different sinks, but same dilemma. I bought a ptrap adapter to plug into the 1 1/2" drain hub. It has threads a washer and hand tighten plastic nut threaded on Is that what is done usually?
    [​IMG]
  7. Terry
    Aug 17, 2004
    Yes. We use those trap adapters, either hub or spigot depending on whether you are gluing into a hub or onto a pipe.
    The p-trap is tubular and can be assembled using your hands. Easy to remove and work with.
Similar Threads: drain help
Plumbing Forum, Professional & DIY Advice HELP PLS - Drainage for Filtration and Softener System Thursday at 9:19 AM
Plumbing Forum, Professional & DIY Advice Drain location help Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Help with kitchen sink drain pipe Jan 16, 2017
Plumbing Forum, Professional & DIY Advice Masterbath drain HELP Dec 14, 2016
