Drain flange for tile floor
Discussion in 'Toilet Forum discussions' started by MikeQ, Jul 24, 2012.
  1. MikeQ
    MikeQ Member
    Jul 17, 2012
    Washington
    I'm replacing the drain flange (ABS pipe) to install a tile floor.
    Are any brands/types better than others or is it pretty much a standard product regardless of the floor covering? Does anyone make one with an eccentric offset so the drain position can be adjusted a half inch or so in any direction without re-plumbing? This could be useful in the future since toilets vary in their wall clearance a bit.
    Thanks,
    Mike
  2. Terry
    Aug 17, 2004
    No.
    However you could install a 4x3 closet 90 with 4" closet flange, and within that 4" opening you could shift the bowl around.
    I like the flanges with metal rings over the plastic flanges. Sioux Chief a TKO with a nice stainless ring. That comes in a 4x3 though.
    They sell a flange extender too, that stacks the flange higher then the subfloor. It's a spacer that goes under the flange.
  4. MikeQ
    MikeQ Member
    Jul 17, 2012
    Washington
    Thanks Terry.
    Would it be preferable to install the flange on the subfloor with a spacer under the flange (and tile up to the flange) or to install the flange directly on the tile?
  5. jadnashua
    Toilet flanges are designed to be installed on top of the finished floor, and be anchored through them into the subflooring. While you can add an extender to an existing one during remodeling, it does add one or more joints that could leak.
  6. MikeQ
    MikeQ Member
    Jul 17, 2012
    Washington
    When you say "leak" are you speaking of sewer leakage? It sounds as if Terry was talking about a spacer that goes under the flange and therefore would not create additional joints that could leak. I'm far from an expert here but it does seem like mounting the flange on top of the plywood (with a spacer underneath) and tiling to the flange (with a caulked joint between tile edges and flange) would provide the neatest install. Do you see it otherwise?
    I realize either way would probably be fine.
  7. jadnashua
    The seal from the toilet to the flange is for two purposes (discounting the important hold the toilet to the floor!): prevent sewer gasses from escaping and second, keep waste from leaking. Note, that second issue often only becomes an issue if there is a blockage, and subsequent backup.
    If you don't get the seal between the spacer and the flange sealed properly, it can leak in either or both manners.
  8. Terry
    Aug 17, 2004
    If I'm there before the tile and I have the spacer with me, that's how I install it. It doesn't' add any more joints. All it does is lift the flange a bit higher.
  9. jadnashua
    It's one thing to add a spacer under the flange to raise it, and another to add one on top of an existing flange. The later is what people usually use the spacer for - raise an existing flange for remodel. But, obviously, it can be used the other way, too.
  10. Terry
    Aug 17, 2004
    I don't bother installing spacers on top. Those are the ones that fail. I would rather use two wax rings. Those work.
    Spacers on top, unless you goo them up with Silicone between spacers, is a guaranteed leak ready to happen.
  11. hj
    There are offset flanges, but they offset more than 1/2" and do NOT fit every situation.
Similar Threads: Drain flange
Toilet Forum discussions Saniflo Sanicompact drain thru wall to toilet flange in other room? Sep 2, 2015
Toilet Forum discussions Help connecting a PVC toilet flange to an existing brass drain Jul 23, 2013
Toilet Forum discussions Gap between toilet drain flange and bathroom floor tile Sep 24, 2011
Toilet Forum discussions Move basement toilet drain 4 3/4" over. Options:1/8 bend, closet bend, offset flange? May 4, 2010
Toilet Forum discussions toilet drain/flange to wall distance Aug 11, 2009
