drain code HELP!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Racerxjling, Oct 24, 2004.
  1. Racerxjling
    Racerxjling New Member
    Oct 24, 2004
    Hello
    Anyone know if it is building/plumbing code to run a sink drain along the wall ABOVE the foundation? We are trying to add 3 sinks to a small commercial business. All 3 sinks will be in 1 line w/ the existing sink. We didn't want to sawcut the foundation if possible.
    Thank you
    Jeff
    Riverside, CA
  2. jadnashua
    I'm not a plumber...I read a lot and lurk here. If you can provide the proper pitch for the drain - 1/4" per foot until the point where it goes down to the sewer and you can provide the proper venting, then I don't think you will have a problem. Asthetics may fail, but code probably wouldn't. The pipe needs to be supported - code would say at what intervals.
  4. hj
    drain
    As long as you have the proper venting and pitch, there is no difference whether it is above the floor or under it.
  5. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Water doesn't Know
    What? Water doesn't know whether it's above the floor or below it :rolleyes: ?
  6. hj
    nope
    Nope. The only way it could tell was by measuring how far it falls before it goes horizontally. Since it is dark inside the pipe, the water cannot use a ruler to make that determination, and so it has to guess using the time it takes, while also computing its acceleration. But it also cannot read its watch in the dark, so it has to use "One second", "two seconds", etc. which can be inaccurate for the slight difference between the two locations.
Similar Threads: drain code
Plumbing Forum, Professional & DIY Advice Is my drain/vent plan code compliant? Dec 5, 2016
Plumbing Forum, Professional & DIY Advice Foundation Drain to Sump - Code Rqmts? Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Move shower drain to other side of joist. Does it meet code? Apr 11, 2016
Plumbing Forum, Professional & DIY Advice help understanding code - drains Dec 27, 2014
Plumbing Forum, Professional & DIY Advice Is this drain arrangment code OK? - Update Apr 15, 2014
