drain auger, problems w getting it in far enough
Discussion in 'Drain Cleaning' started by msgale, Jun 9, 2008.
  1. msgale
    msgale Member
    Sep 28, 2006
    situation is a 4" driveway drain, clogged w/ leaves, gravel, etc. from rainfall over the entire driveway.
    I used a half-inch electric auger. But i cannot get it to advance very far, maybe 10 ft or so, and even that's a struggle, advancing it a couple of inches at a time. i tried both a small spade tip, about 1 inch diam, and a little bit larger about 1.5 inch auger type tip. Is there any particular technique to get it to advance?.
    i am pretty sure i remember renting a 1 inch auger years ago, which went in pretty far. Does a fatter cable hold its position better to advance forward?
    can i be sure it won't be too stiff to get it past the p-trap?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Outside drains = Dirt in the line!
    Generally speaking cables and blades have a tough time doing these lines going through the dirt.
    Add to that they are often substandard thin polyethylene or corrigated plastic pipes that are crushed flat. Blades will also chew these pipes up.
    I would recommend having this line High Pressure Jetted!
  4. msgale
    msgale Member
    Sep 28, 2006
    house built in 1924,assume drains installed then
    probably cast iron
  5. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Driveway Drain
    Probably Concrete Or Terri Cotto Clay 12" Peices With A 1" Space At Joints
    And Yes Your Cable Is Way To Small,
    You Need Water Flowing To Move Dirt And Trash Though Pipe
  6. hj
    drain
    Your cable is vastly undersized for the chore you have chosen. In addition, the best way to unplug it is to come upstream from the outlet and wash out the debris as the snake or jetter loosens it.
  7. msgale
    msgale Member
    Sep 28, 2006
    can't go from downstream, it's city sewer. But I can..
    rent a One inch auger, which will be next step.
    thanks for help.
  8. hj
    auger
    And be sure you have good medical insurance because a 1" auger in a packed sewer can break fingers, wrists, or arms very quickly. Besides getting caught in a shirt or pants and winding up so tightly that circulation is cut off. If you damage the snake cable, it will also be EXTEMELY expensive to replace it.
  9. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Msgale, you posted a problem on this forum seeking advise. You received some very sound advise from some very knowledgeable people who are not trying to sell you anything. In spite of this, you seem to insist on ignoring this help. You are getting in over you head in terms of experience and training. I urge you to heed the advise and warnings of these experts before you damage yourself and/or your drain.
  10. Terry
    Aug 17, 2004
    I had to run a large snake when I was younger a few times.
    I won't touch them now.
    For starters, like hj has mentioned, they are very dangerous.
    Watching an expert is a start, and even then, there is more to it than that. Some of it you will learn the hard way. You need to feel what is happening down line, and know what has to happen when you feel it.
  11. hj
    snake
    One plumber was killed when his snake got caught in his shirt and squeezed him like a boa constrictor.
  12. msgale
    msgale Member
    Sep 28, 2006
    i appreciate the warnings,
    But why i am being chastised for ignoring them?
    I just saw them this minute,after my last post.
    i like doing my own repair work, but we all have our limits, and it sounds like the bigger auger should be considered past mine.
  13. Gary Swart
    Sep 1, 2004
    Yakima WA
    I don't want to escalate this into a war, so I'll just say this and quit. The reason we jumped on you a bit hard is that you were given 3 separate answers all telling you that a small snake alone was ineffective and that jetting was probably the best solution. You responded by saying you were going to get a 1" snake which is definitely a professional tool that should not be even considered by a DIYer. This appeared to me, and I believe others, as ignoring the advise offered. Certainly advise offer here is free and you always have the choice not to take it. If we jumped a bit hard and/or prematurely, remember, most of us are not word smiths and sometimes our answers and be quite terse and untactful. You are welcome here, just don't take offense if some of us sound a little harsh.:)
  14. msgale
    msgale Member
    Sep 28, 2006
    i wasn't aware that a one incher was considered..
    professional or more dangerous, until the later posts.
    thanks for the clarification.
  15. hj
    snake
    Actually your 1/2" snake can be as dangerous as the larger ones under the right conditions. ANYTHING that rotates can injure a person, and a stuck cable/snake can exhibit some wild behavior if if it is torqued too much.
  16. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Just out of curiosity, how big do these snakes come?
  17. Terry
    Aug 17, 2004
    Cause we love you buddy!
    I don't think anyone has chastised you.
    We are just giving you our opinion based on experience of what can happen with these machines.
    I think the best advice here was about the jetter.
    Thats what the city utilities are using to clear their lines.
Similar Threads: drain auger
Drain Cleaning Dropped plastic handle for auger down the washing machine drain pipe Aug 15, 2013
Drain Cleaning 100 year old drain line professional augering?The kind with blades to remove build-up Aug 5, 2013
Drain Cleaning Getting #*$% drain auger past 90. Oct 19, 2010
Drain Cleaning Two Droplets of drain cleaner Saturday at 10:07 AM
Drain Cleaning Plugged 2" copper drain Jan 11, 2017
