Drain and vent question
Discussion in 'Shower & Bathtub Forum & Blog' started by Daveclink, Jan 4, 2013.
  1. Daveclink
    Daveclink New Member
    Feb 26, 2012
    Syracuse, NY
    After completely gutting my bathroom I have a number of questions about the original install of the vent and drain pipes and how to fix the issue.
    The drain pipes and vent pipe are 1 1/2 PVC
    The drain pipe to the right will be contected to a double sink with a separate vent connected to the existing stack. Do I need to change all the pipes to 2"?
    about 7 feet away from the double sink will be the shower. Will I need a separate vent for the shower? If so can I connect it to the exixting stack.
    can I connect a 2" drain to a 1 1/2 vent?
    Any help would be greatly appreciated
    Dave
  2. jadnashua
    The size of the vent is determined by the number and type of fixtures it must vent - for a sink and shower, 1.5" should be okay, but typically, in cold climates, it must be upsized before it goes through the roof to prevent hoar frost from closing it off.
    The shower and in-wall drains for the vanity should be 2", and you may be able to wet vent the shower from the lav, if it is done properly. Otherwise, the shower will need its own connection into the vent.
  4. Daveclink
    Feb 26, 2012
    Syracuse, NY
    Thank you, Jim
    I will replace all the 1 1/2" with 2"'
    Can I stay with the same type of connections as in the picture?
    You can't see it in the picture but the drain/vent pipe is connected to the 3" waste pipe about 1 foot below the elbow
  5. hj
    That picture is almost useless because of all the intervening "stuff" which obscure the drains. Many plumbers, but not me, run sink drains using 1 1/2" pipe. The shower drain should be 2". As for vents, the actual way the drains are installed would determine where vents would be needed.
Similar Threads: Drain vent
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Installing a washer drain 1 ft from main stack - is vent necessary? Jul 17, 2016
Shower & Bathtub Forum & Blog Shared Drain Vent Question Jul 7, 2016
Shower & Bathtub Forum & Blog Venting and existing drain connection concerns Mar 14, 2015
Shower & Bathtub Forum & Blog Your Beach House Shower: Best way of preventing sand build up in drain Dec 19, 2014
