Drain and Supply Capped For Future Use
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by philwgreen, Jul 31, 2013.
  1. philwgreen
    philwgreen Member
    Apr 15, 2013
    Dallas, TX
    Ran into some problems with the DWV system. Details in this thread. http://www.terrylove.com/forums/showthread.php?53081-Question-About-Running-Pex&p=387111#post387111
    I started a new thread because of a new, related issue. It seems like my problems in the other thread could be solved by adding a lav and making my vent a wet vent. Adding that lav is not a problem design wise, but it was something that could ideally be added in the future and not be part of our current build.
    Is it possible to leave the drain and supply lines capped for future use? I just wasn't sure if that was within code. Also not sure how that works with my inspection process - but if it is within code, I'm guessing it will come down to which inspector I get and what kind of mood he's in that day.
  2. hj
    IT is done all the time and there is usually no code issue, unless the sink location is a prohibited one, such as here, you cannot have a stubout for a kitchen sink in a detached casita, because they do not want it converted into an apartment.
  4. philwgreen
    philwgreen Member
    Apr 15, 2013
    Dallas, TX
    Thanks. The location of the sink is not a problem. The garage addition with the living space above is physically attached to the main house. Luckily, I already went through all of those zoning questions with the city when pulling a permit.
Similar Threads: Drain Supply
Plumbing Forum, Professional & DIY Advice Bathroom drain and supply Lines Jun 22, 2014
Plumbing Forum, Professional & DIY Advice Can I seal off an old Wet Bar drain and supply lines Feb 18, 2013
Plumbing Forum, Professional & DIY Advice How should I update this supply/drain to bathroom sink? Feb 4, 2012
Plumbing Forum, Professional & DIY Advice Moving Drain (& supply lines in the way) for shower Nov 11, 2011
Plumbing Forum, Professional & DIY Advice What's the requirement when a buried PEX supply crosses over a buried drain line? Jun 28, 2011
