Double sanitary tee in Canada
Discussion in 'Canadian Plumbing Code Questions' started by segal46, Jun 19, 2010.
  1. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    so is a double san tee the same as a back to back fitting??
  2. Terry
    Aug 17, 2004
    A double santee is not the same as a double fixture cross or fitting.
    You may have to print out the page and bring it in.
    [​IMG]
  3. segal46
    segal46 a/v technician
    Feb 10, 2010
    a/v technician
    montreal , QC
    and I thought here in Montreal I had problems finding a dst and a dcf I found one at Wolseley, a plumbing reseller which they have in all Canadian provinces or you can purchase a dst online at home depot only on delivery
    I actually called the part manufacturer who couldn't sell it to me cuz i,m a nobody,lol, they only sell to resellers, a bribe to the guy on the phone didn't even work for a 5 dollar part, where is this world leading to, i tell you.
    the part NUMBER at wolseley is ABSTYD2X1K
    good luck
    Sergio
  4. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    thanks terry i printed one out last night.
  5. hj
    The factory would not sell it to you, because they do NOT sell individual items and you did not want a box of them. Also, they would have had to create an account for you with all the paper work it entails, INCLUDING a means of charging and reporting any sales tax, or VAT. NONE of their customers pay the sales tax, so you would have created an unusual situation for them with a lot of beaurocracy paperwork.
  6. segal46
    Feb 10, 2010
    a/v technician
    montreal , QC
    Isnt the customer always right, though I totally understand and agree with your point. Just that when I was told that here in my province none were sold to retailers since February, and thousands sold across our country, common courtesy of trying to help a fellow human goes a long way. Just a thought of the day.
  7. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    i found this one at lowes in brampton in the toronto gta i hope this is the correct one cause ive run out of places lol
  8. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Sorry, that is a double sanitary tee.
  9. Terry
    Aug 17, 2004
    Give me a couple of hours and I will post a picture of what you can do.
  10. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    thanks terry!!
  11. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    OK, good to know. I'll remember all this next time I need this.
    1. a bribe over the phone doesn't work, in Canada.
    2. Wolseley ABSTYD2X1K.
  12. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Very few people in Canada actually even know a double fixture fitting exists; it is not used at all (neither are long sweep fittings for that matter). It is a part that has to be special ordered by the supply house from the manufacturer...and you have to know the catalog # to get them to order the proper fitting...if you just tell them you want a double fixture fitting, they will try to give you a double sanitary tee or look at you strangely. Many plumbers know that a double sanitary tee is bad, but they end up using a double wye instead...which is even worse than a double sanitary tee for other reasons.
  13. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    any chance of getting that picture terry. thanks
  14. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    vent.GIF How about something like this? It adds some fittings and pipe, but would eliminate the s-trap. If the double combo was used, the cleanout probably wouldn't be needed.
    We'll see what the pros say. Terry might have a better way of doing it (I just quickly pulled something together that should work).
  15. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    well could this be another possibility.
  16. Terry
    Aug 17, 2004
    You have 2" from the bottom?
    Then why were you showing a 1.5" double san cross before?
    The laundry tub should have a 2 x 1.5 x 1.5" santee if you are coming up from the vertical.
    Or the 2 x 1.5 x 1.5 x 1.5 fixture cross would have worked.
    The picture below is a 1.5" being split for two lavs without the cross fitting.
    To be UPC legal, it would need 2" until it's split.
    But if you only had 1.5" in the floor, this would be the best fix.
    [​IMG]
  17. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    yes this looks alot more compact than mine, would mine even pass terry?
    the 2" is the main drain that will go to the 3" drain. i have the toilet wet vented through the lav as the last vent before the entrance to the 4 " drain to the sewer
    i was showing the san tee last night when you said you were going to post a pic, then i tried to draw a pic as well hense the new setup.
  18. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    this is what i was going to do until i was told not to use a double san tee
  19. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    I'm not a big fan of the short sweet 90's you have there, but if you changed those to 45* elbows your setup would be 100% code legal here in Canada.
  20. Terry
    Aug 17, 2004
    The family had a log cabin in Canada.
    The toilet was an outhouse, code legal, and the kitchen sink was a pipe that went outside into the sand, that was code legal too.
    Can a da.
    Where the bears drink beer.
    We had a bear that would come around mainly at night.
    In the US, were still not big fans of the code legal in Can a da san cross. That's always been a tough one to snake.
    But then there are rough-in plumbers, and there are service plumbers.
    When you get tired of doing crawlers, you become a service plumber.
    Though, I had to slither a crawl today for a repipe bid that the young guys will be doing.
    What was I thinking, after three surgeries on through my stomach muscles this Winter, that was hard.
    [​IMG]
    [​IMG]
Similar Threads: Double sanitary
Canadian Plumbing Code Questions Double sink in bathroom Nov 28, 2014
Canadian Plumbing Code Questions Can I replace 2 separate wye's on the stack with 1 double wye fitting on the stack? Oct 12, 2013
