Double sanitary tee in Canada
Discussion in 'Canadian Plumbing Code Questions' started by segal46, Jun 19, 2010.
  1. segal46
    segal46 a/v technician
    Feb 10, 2010
    a/v technician
    montreal , QC
    Hi all,
    My question pertains to a double sanitary tee 2inch reduced to 1-1/2, i've been searching everywhere in Montreal, seems plumbers here dont like to use it as much as elswhere, though through shipement i will end up paying double for it, sic quebec is distinct for its own reasons...lol.
    How many plumbers use double sanitary tee's and if not why not, i will be using it for 2 sinks in different rooms, leading to a 2 inch drain.
    thanks
  2. hj
    It, along with a double combination Y-1/8 bend, is ILLEGAL for that use in this, and most areas using the UPC. The IPC might allow it, but I am not sure about that. You are supposed to use the proper fitting, which is a "back to back fixture fitting", (R&G Sloane #91491 in ABS), which comes in 2x2x1 1/2x1 1/2, 2x1 1/2x1 1/2x1 1/2, and all sides 2", plus larger sizes.
    Double fixture cross
    [​IMG]
  4. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    unfortunately ( if you are in the drain cleaning game ) IPC allows it
  5. hj
    As you can see, by the insert which was added to my posting, it appears similar to a double combo. However, the branches are attached higher up on the barrel to eliminate the creation of a 3/4 "S" trap, which would occur with a double combo. A sanitary cross is a "terrible" fitting to use in its place because while it is not impossible to snake the vertical line through one, by the time you succeeded you would have called it every name in the book that would have gotten your mouth washed out with soap when you were younger.
  6. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    double san tees are probably the reason why they came up with the drop head for your snake
  7. hj
    Even they do not always work. The spinning head will usually flip up and enter the opposite side.
  8. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    Even better is when the whip around and crack the fitting
  9. hj
    Well, I have never had that happen, but if it did, it would mean the fitting was already done for, and you just helped it along.
  10. segal46
    Feb 10, 2010
    a/v technician
    montreal , QC
    Why would I need to fish sinks when they lead to a 2inch vertical drain with a drain plug, they are bathroom sinks hand washing and soap will probably be the worst they see.
    Just a thought to the responses which where somewhat confusing, though I understand by the pic Hj put up the higher curb on the double fixture cross
  11. Terry
    Aug 17, 2004
    Are you kidding me?
    Have you never snaked a lav drain and seen what comes out on the end of the snake.
    Lavs have nasty stuff. Snaking lavs is one of the most common things I do for people. Many homes have slow lav drains over time.
    That's why plumbers are called in, and when the piping in the wall has the wrong fittings, it creates problems for the life of the home.
    Not just a year or two, for the life of the home.
    I'm getting hungry just looking at this
    [​IMG]
    Looking inside a sink drain, you know this stuff smells good.
    [​IMG]
    Stuff we find inside of pipes
    [​IMG]
  12. segal46
    Feb 10, 2010
    a/v technician
    montreal , QC
    Lmao, point well taken and understood ,guess that's why i,m not a plumber just a do-it your-selfer and seeing that you posted those yummy pictures I will take pride in doing the job right.
    thx
    Sergio
  13. hj
    A person who uses a sanitary cross for that connection, is usually not experienced enough to KNOW that you also put a cleanout tee below it. I had a motel where EVERY two sink connection was a cross and there were NO cleanout tees. I had to make openings in the wall, and drill a hole in the vent above the fitting to snake it. Then I put a "repair clamp" over the hole to prevent leakage.
  14. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Doubt San-T's are perfectly legal here in Canada according to the National Plumbing Code of Canada. In fact if you have two sinks sharing a common vent through a semetrically connected fitting then that fitting HAS to be a Double San-T. Because if it's not you're a creating an S-Trap and you are not allowed to install S-Traps. You also MUST install a cleanout below the Double San-T because every plumbing system needs to be designed so that each and every soil-or-waste pipe can be snaked from inside the house.
    You should be able to find yourself a 2x1.5x1.5" double san-T. If you can't then just buy a 2" double san-t and get three 2x1.5" bushings.
  15. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    would my setup work for a lav back to back with a laundry tub,with a cleanout underneath it ?
  16. Terry
    Aug 17, 2004
    No. That makes S-Traps what will siphon.
    The vent needs to pull off of the top of the pipe, not six inches lower.
  17. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    so, if i put the 90's on the top of the y's that would be ok cause it is lower?
  18. Terry
    Aug 17, 2004
    You can't use a wye fitting for back to back fixtures.
    [​IMG]
  19. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    Thanks Terry I'll do it this way
  20. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    does anyone know where in canada (toronto area) i can get this double sanitary tee?
    they don't have it at hd. i also went to a plumbing outlet no luck, thats why i got the double y
  21. hj
    drain
    quote; In fact if you have two sinks sharing a common vent through a semetrically connected fitting then that fitting HAS to be a Double San-T. Because if it's not you're a creating an S-Trap and you are not allowed to install S-Traps.
    Aren't you reading anything that has been said. The "back to back fixture fitting" DOES NOT create an "S" trap, which is why it is REQUIRED in most areas.
Similar Threads: Double sanitary
Canadian Plumbing Code Questions Double sink in bathroom Nov 28, 2014
Canadian Plumbing Code Questions Can I replace 2 separate wye's on the stack with 1 double wye fitting on the stack? Oct 12, 2013
