Double Lugging
Discussion in 'Electrical Forum discussion & Blog' started by jaxbldginspector, Oct 2, 2008.
  1. jaxbldginspector
    jaxbldginspector New Member
    Mar 19, 2008
    Does double lugging only pertain to circuit breakers or can it pertain to the load side of a meter socket?
    Does the NEC mention anything about double lugging?
    Thanks for any information provided.
  2. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    It could pertain to anything. Or in other words, anyone could do things anywhere which they should not do or would be ok to do.
    The question is... Did the manufacturer design the lugs for only one wire or for two wires? Or does the manufacturer's specifications say that two wires are permitted on that lug/screw terminal?
    Here is an example of a manufacturer's specs for lugs.
  4. Billy_Bob
    Apr 2, 2008
    P.S. Also what wire is connected in the case of a neutral bar. The manufacturer may say it is ok to connect two ground wires, but not ok to connect two neutral wires - same size wires, same screws, same bar - different use.
Similar Threads: Double Lugging
Electrical Forum discussion & Blog Double lugging Sep 8, 2009
Electrical Forum discussion & Blog Replacing double 3/way switch May 25, 2016
Electrical Forum discussion & Blog Wiring a double oven. Sep 23, 2015
Electrical Forum discussion & Blog How To Wire a Square D QO220GFI 240v, 20-amp Double Pole Breaker Jan 26, 2015
Electrical Forum discussion & Blog Can I use 2 single pole 30 amp pushmatic breakers as a double pole set up May 28, 2014
