double check valve same as backwater valve ?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Pan, Feb 26, 2008.
  1. Pan
    Pan New Member
    Feb 13, 2008
    I just spoke to a plumbing company to install a BWV and she said you mean a backflow valve or a doublecheck valve.... I told her it goes on the sewer line, she said the doublecheck valve is also the same thing.
    I am not sure they are the same thing- the double check valves seem to be on the supply lines to prevent some kind of cross contamination. This is getting complicaated VERY fast!
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    You are correct... It is the office help that doesn't know!
  4. jadnashua
    It makes it really hard to follow your whole problem when you start a new thread with each question...same problem...keep it in the same thread. The history of what was asked and answered will also help keep things on track.
  5. Pan
    Pan New Member
    Feb 13, 2008
    Will do- different forums have different rules
    if it is a seperate question- inspite of it beingl the same problem, but a seperate concept, they tend to wnat to see it in a different thread.
    But I will just post to the original thread from now on.
  6. jadnashua
    How long have you been here? It shows you've made 16 posts.
    It's not a big deal, but you are trying to solve a single problem...seeing the progress of ideas is MUCH easier if it doesn't bounce all over the place...otherwise, there is absolutely no connection that is useful later on. Search would find the though, regardless of where it is in the thread.
  7. hj
    thread
    Who is going to take the time to do a search for a previous question. A check valve by definition is a restriction in the sewer's flow, and if you use two or more it compounds the problem. She did not know what you were talking about and was thinking about a water supply anticontamination valve.
Similar Threads: double check
Plumbing Forum, Professional & DIY Advice Installed Vents. Please Doublecheck My Work. Thanks! May 3, 2016
Plumbing Forum, Professional & DIY Advice Checking my plumbing - single sink to double sink Aug 8, 2014
Plumbing Forum, Professional & DIY Advice double sink vanity rough plumbing -- please check my plan Jul 29, 2014
Plumbing Forum, Professional & DIY Advice Moving toilet - need someone to double check my idea... Feb 2, 2013
Plumbing Forum, Professional & DIY Advice Can you guys double check my drainage? Oct 31, 2012
