Door patch product recommendation
Discussion in 'Remodel Forum & Blog' started by Mike50, Aug 31, 2006.
  1. Mike50
    Mike50 DIY Senior Member
    Jan 8, 2006
    Southern California
    I'm prepping 2 standard size exterior wood doors for painting.
    Both doors have 1/8-1/4 inch gashes from dogs scratching at them when they get crazy.
    What is the best patching material to use? Mud-Joint compound....or?
    These doors are exposed to direct desert sunlight much of the day. Up to 120 degrees on occasion.
    M.
  2. Bassman
    Bassman DIY Member
    Aug 25, 2006
    musician
    Ventura, CA
    I don't know what the pros use, but I've been using Bondo for some time now with lasting results.
  4. prashster
    prashster New Member
    Dec 7, 2005
    I've never tried it, but a lot of people swear by automotive putty. 3M makes something called Super Red. Harder, and less shrinkage than wood filler (2nd best). If it were me, I wouldn't use dwall compound. Too brittle for exterior
  5. jadnashua
    There are some epoxies that are made to fill in. Hopefully, the door is going to be painted, otherwise, regardless of what you use, it will look funky unless you can do faux finishing well. The epoxy would have a little flexibility and strength, I think.
  6. Mike50
    Jan 8, 2006
    Southern California
    OK. I just read on a painting board where 2 pros say that bondo is the way to go.
    You cant hurt the stuff. It has a 10 minute dry time window as the downside.
    Glad I asked-I would have knifed in some fix-all being a knucklehead.
    thanks..
  7. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I just filled a fist-sized hole in a door with vinyl spackling (2 coats). Sanded it a couple of times, and painted it. Can't tell there was ever a hole. Love that stuff.;)
  8. Mike50
    Jan 8, 2006
    Southern California
    Filling the hole and having it look good after painting isn't the problem Verdeboy. Selecting the right media that wont shrink and fall out after a year or two is key. As I said it's exterior/exposed to rain and triple digit digit desert sun.
    2 painters recommended Bondo and it makes sense in this case.
  9. Verdeboy
    Jun 12, 2006
    Many painters and handymen use vinyl spackling for exterior door and wood siding repairs. That's how I learned about it. It's strong, somewhat flexible, easy to use, sands easily, is pre-mixed, doesn't dry too fast, and doesn't shrink. The only time I've ever used bondo is for fixing my rusty old car. LOL
  10. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    door shops use bondo
    cars are out in the rain also:rolleyes:
  11. Mike50
    Jan 8, 2006
    Southern California
    Verdeboy:
    If your particular vinyl spackling tub reads interior/exterior use which I suspect it does, you still have to use common sense. Bondo is a stronger-more reliable product. Even I know that and I dont know a lot about this. I say this based on a number of pro opinions..
    What kind of exterior door am I talking about here:
    In summer it will heat up to 130 degrees in direct sun as a guess. And there is little protection from rain water. The door
    is going to get knocked by shovels-wheelbarrows-pitbulls etc. Get the picture?
    So I'm not talking about patching a wooden garden gazebo out in the Hamptons here....see? lol
    Bondo Corp. apparently has formula for any surface you might imagine.
    Bondo Wood Filler:
    http://www.bondo-online.com/catalog_...sp?itemNbr=101
    Bondo Home Solutions Product Line.
    http://www.bondo-online.com/about.asp
    Bondo Home Solutions catalog:
    http://www.bondo-online.com/catalog_brand.asp?hdrBrand=2
    To be fair--I doubt you knew about the Home Repair line. I did not.
    I also don't know if Vinyl spackling formula is similiar to Bondo.
    Maybe someone does.
    M.
  12. Verdeboy
    Jun 12, 2006
    You started out this thread by saying you had a couple of medium size gashes in your door, and you wanted to use drywall mud to fill them. Vinyl spackling may not be the best thing in the world for door repair, but it's infinitely better than joint compound.
    Now you say the door is going to take a beating from dogs and equipment. Your best bet is to install a large metal kickplate or just replace the door with a metal one. No wooden door is going to take that kind of abuse. Get the picture?
  13. Mike50
    Jan 8, 2006
    Southern California
    Nope. I don't get the picture-it's wood for a reason. It's a utility back door into a garage in the Mojave Desert. A metal door or kickplate would probably heat up to 140+ degrees in summer and potentially hurt the dogs.
    The joint compound became a non-issue 10 days ago. Your comment is non-sequitor, if you read the thread
    Vinyl is Vinyl. Bondo is Plastic. It's more dense. To be fair, I've read that the Vinyl is probably easier to spread.
    If you want to debate why Vinyl Spackling would be better than Bondo for this application hey--go right ahead. No problemo..
  14. chassis
    chassis Engineer
    Sep 12, 2005
    Engineer
    SE Pennsylvania
    Here's two more cents. I just filled a 3/8" hole in my entry door with Bondo. Worked great. Sanded it and painted it, can't tell it was there. The hole was left over from the old lock set that I replaced with a new one. Luckily the exterior trim of the new lock set covers the hole on the outside. The door is stained on the outside and the hole would have been a pain to deal with.
    I just ordered a quart of WoodEpox, from Abatron. www.abatron.com. They sell it as a fix-all for wood restoration, filling, etc. I have a screen door closer that pulled out of the jamb, and I'm going to try WoodEpox to repair the hole.
  15. prashster
    Dec 7, 2005
    I've used chewing gum with considerable success. Comes in plenty of colors; you don't even have to paint it.
  16. Verdeboy
    Jun 12, 2006
    Now you sound like some of my previous tenants. They think they're doing me a big favor by filling all their drywall holes with toothpaste. Just makes a big mess!!
  17. prashster
    Dec 7, 2005
    But leaves your place smelling minty-fresh!
  18. Verdeboy
    Jun 12, 2006
    I think you're onto something Prash. Scented spackling. I can see it now: mint scented spackle, strawberry scented spackle, curry scented spackle...
    I want to be on the bottom floor on this one!
Similar Threads: Door patch
Remodel Forum & Blog Best Patio Door Manufacturer Sep 6, 2015
Remodel Forum & Blog Tiled Doorway In Adjoining Areas Feb 24, 2015
Remodel Forum & Blog Good Source For Door Hardware Sep 15, 2014
Remodel Forum & Blog Framing a door Mar 25, 2014
Remodel Forum & Blog actual door opening width Mar 19, 2013
