dont need p-trap in vanity drain?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by zxed, Feb 1, 2009.
  1. zxed
    zxed New Member
    Dec 7, 2008
    California
    okay so maybe the title is a little misleading...
    my double vanity sink came with this "thing" (see attached)... it seems as if this is supposed to work as a p-trap and connect to a stubout/drain... but from what i see, it looks like a 1.25" in and 1.25" out... how am i supposed to connect this to my abs/stubout ?
  2. Terry
    Aug 17, 2004
    An ABS trap adapter with slip joint washer, and an 1-1/4" tailpiece I assume.
  4. zxed
    zxed New Member
    Dec 7, 2008
    California
    it shall be a long day at home depot... walking through isles and isles.
    i dont remember seeing anything smaller than 1.5" .. but i think that was just in the abs section..
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It's a bottle trap...
    Not legal under a lot of codes because it relies on an internal partition to provide a trap seal which may corrode and fail but there is no way to know if that has happened.
  6. zxed
    zxed New Member
    Dec 7, 2008
    California
    so i need this: abs trap adapter on
    so i need a slip joint washer., or is that already included? the black thingy in the attached pic.,
    that link points to hdepot., but its blocked :)
  7. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Well I guess if the stores sell it, it must be legal. Every plumbing code I ever read does not allow that trap. When it comes time to sell the home, it will fail inspection.
    I just had to give an estimate yesterday on tearing out all the plumbing the homeowner did 3 years ago and bring it all up to code. It got tagged by a home inspector, and when the plumbing inspector came to see what the deal was he wrote up a 15K fine for this home owner for doing plumbing with out a permit and with out a license. Way the fines work is its 5k for first offense and each violation their after it doubles. So he got hit with 5k for the permit and 10k for not being a licensed plumber.
    Moral of my tail of woes to make sure if you do any work check with your local building department about permits and codes. Plumbing codes in most states are the "law" and are enforced as such by "code enforcement officers" which can cost you a whole lot more grief than the few bucks you save. Reason we have these plumbing codes is to ensure the protection of the health to all those in your home as well as the community. And the reason we have licensed plumbers is they studied these codes under an apprenticeship and took the required tests to prove their knowledge. Its just like how doctors have to goto school and intern somewhere before they become full fledged doctors. If we didn't have some sort of system to keep things in check there would be huge epidemics like their was in the dark ages.
    I am real glad you all found these forums and are smart enough to ask questions about whats is the right way to do things. Key about doing anything yourself is do it right the first time, and if you are not sure how to do it right ask questions or hire a pro. If you go for the asking questions part please follow the advice given even if you think it might be to hard to do.
  8. zxed
    zxed New Member
    Dec 7, 2008
    California
    thank you.
    i have and still go between "to get a permit, or not to get a permit" thought process every day.. the issue i am having is that the inspectors in my city are known to inforce "additional" code upgrades... for ex, you request a plumbing permit, get the permit, get the inspector., gives you the okay for plumbing, writes you up for electrical even thought you are NOT at all modifying anything electrical.... and it isnt as simple as, tie down the wire, a simple $100 plumbing job becomes a $2000 electrical job...
    i actually did not buy the bottle trap., it came with the double vanity, i could simply put p-traps in wall..
    in CA, bottle traps are only allowed under special condition, inspectors give the yes/no... i guess i could put the ptrap in the wall,. that way even if the bottle trap corroded., the in-wall ptrap would still be there... and if i do get a permit + inspection the in-wall p-trap should pass..?
    and i do follow advice given., i did re-do the shower plumbing again to remove a s-trap and flat vent.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    You cannot use 2 traps in a row. That would be a double trap which is a real no-no!
  10. zxed
    zxed New Member
    Dec 7, 2008
    California
    Thankyou for the tip..
    I'll sleep on it, maybe i'll dream abt it.
  11. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You also can not hide a P trap in a wall. It goes directly under the sink or tub being drained. I would trash that bottle trap thing and get a conventional P trap. A vanity uses a 1-1/4" drain often increasing to 1-1/2" at the wall. That takes a simple adapter that should be easily obtained at any store selling ABS pipe and fittings.
  12. hj
    traps
    Do that and your next question to us will be, "Why doesn't my new sink installation drain?" And "P" traps for washing machines, tubs, and showers, are almost ALWAYS "hidden in the wall or floor", but that is not a good idea for sinks.
  13. SewerRatz
    Nov 20, 2008
    Chicago, IL
    I do my best thinking while I sleep.
  14. jimbo
    jimbo Plumber
    San Diego, CA
    CA 2007 Code, article 1004.0
    ....No trap that has concealed interior partition, except those of plastic...shall be used. Drum and bottle traps shall be installed only for special conditions.
    article 1005.0
    Each fixture shall have a water seal of not less than 2" and not more than 4".
    Well, the bottle trap in the picture seems to have some plastic in it. I frankly never had occasion to ask for a "special conditions" waiver, so I really don't know if just the aesthetic situation of a pedestal sink is compelling enough to get it approved. Can't tell from the photo if that trap has 2" seal.
    I have seen bottle traps for sale in the box stores. Notably they do NOT have an IAPMO , UPC, or other approval seal noted anywhere.
  15. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I do my best work while 1/2 asleep ;)
    Are homeowners allowed to even replace faucets & "simple" items ?
    Just curious if all plumbing means everything
    It seems it would, but I had a hard enough time getting a plumber here to do $3k of work, never mind installing a faucet
  16. zxed
    zxed New Member
    Dec 7, 2008
    California
    ok, slept on it., think this is a following is a reasonable conclusion..
    the double vanity is from modern bathroom
    daytona double vanity
    with the stubouts placed in the correct location... will i not be able to use the p-trap or bottle trap whenever i feel like it? :) some cutting/glueing may be required. but nothing a sleve cannot fix?
    if there is no design limitation in the vanity, i will use the p-trap. if there is a design limitation (cannot get an extra 4 towels in there) ill use the bottle trap while it works., when im ready to sell (bought the place in 2006, its not going anywhere), i will switch it out for the p-trap... does that solve the problem?
    the bigger problem, or more work involved... imo is that the studs in the wall are 4x2's. ... i need to pass the 1.5 drain and vent through them...
    are there any code violations in passing a 1.5" thru 2x4's directly in center? i need to go pick up a 1.5" flat bit....
Similar Threads: dont need
Plumbing Forum, Professional & DIY Advice Replacing sink...P-trap and drain dont line up Aug 9, 2013
Plumbing Forum, Professional & DIY Advice I just dont get it! Please help! Oct 8, 2011
Plumbing Forum, Professional & DIY Advice I dont know What backflow preventer to buy Jun 30, 2011
Plumbing Forum, Professional & DIY Advice Kohler sink, stains easily...poor materials or just dont make them like they used to? May 27, 2008
Plumbing Forum, Professional & DIY Advice Rads dont get hot with mono valves Dec 13, 2007
