My Toto drake is using many gallons of water and taking a long long time before the tank refills. The flapper valve seems to work OK. If I take the fill tube out of the overflow pipe and let it run directly into the tank it fills very quickly and stays full with no leaks around the flapper. (bowl doesn't fill much that way) From the basement I hear water running through the drain pipe long after the flush but this occurs only when the tube is properly filling into the overflow pipe. I Installed the toilet in Aug. in a house we just built. The floor is level and It worked great at first. When I started having problems I wondered if the fill tubing got moved but Terry posted a picture of the correct set up. How could it be draining out?
I've got to say that the toilet still flushes every time even though I've been running the water directly into the tank and the bowl then holds very little water to start with.
