Does trap size matter?
Discussion in 'Toilet Forum discussions' started by cindyw, Jan 26, 2006.
  1. cindyw
    cindyw New Member
    Jan 26, 2006
    I'm thinking of buying the Toto Dartmouth which has the G-Max flush. (We're tired of plunging.) My husband thinks the American Standard Champion will work better because it has a 2 3/8 inch trap opening compared to 2 1/8 inches on the Toto. Will the size difference affect the flush? Thanks!
  2. Terry
    Aug 17, 2004
    Most trapways are 2-1/8" with the larger (3" or more) flush valves.
    That has been a good size.
    Some companies are using slightly bigger valves and trapways, mostly so they can say "bigger".
    Toto was about 15 years ahead of the others in coming out with the new design that has just recently been copied by others.
    Is bigger better, or is it marketing hype?
    There isn't that much difference between 2-1/8" and 2-3/8" to make much difference. You're talking 1/4".
    If you have waste leaving your body that is bigger than 2" in diameter, then maybe it does.
    Most people don't.
    The MaP testing is based on 7/8" in diameter waste.
    Both toilets use siphon flushing. Too much size, and you loose siphon. Otherwise there wouldn't be a limit on size.
    The biggest flushing problem I"ve had with a Champion in a friends home, was when the trip lever starts to wear in and it doesn't let enough water out of the tank to complete a flush. That has nothing to do with size though.
    I replaced the tank on that one, and so far it's doing the job. That also fixed the the leaking seal problem.
    I don't like how shallow the bowl is though. The deep part doesn't seem placed right.
    If size does matter to you, and it could with certain medical conditions which results in large than normal bowl movements, you could consider something in the 3" to 4" range, which the Caroma toilet uses. The Caroma uses a Wash down flush.
    The Caroma doesn't flush as much miso paste as the others at one time, but with the larger openings, you can drop bigger things through it.
    That all being said, most of the new toilets that use a 3" or larger flush valve and a trapway of 2-1/16" or larger will flush better than previous versions.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Area matters
    "There isn't that much difference between 2-1/8" and 2-3/8" to make much difference. You're talking 1/4"."
    Flow rate is proportional to area for the same head (pressure).
    (2.375 squared)/(2.125 squared) = 1.249.
    The 2 3/8 unit has 25% more area.
  5. RRW
    RRW New Member
    Jul 15, 2005
    Illinois
    You guys are killin me. The area of a circle equals pi times the radius (1/2 the diameter) squared. there is a 20% difference between the two sizes in question. Regards, Dick
  6. Bob NH
    Oct 20, 2005
    New Hampshire
    Sombody needs a new calculator.
    Area = Pi x Radius squared = Pi x diameter squared /4
    Pi = 3.14159
    Area of a 2.375 dia circle is 4.43013
    Area of a 2.125 dia circle is 3.54656
    4.43013 / 3.54656 = 1.249
    That’s 24.9% more area.
  7. RRW
    RRW New Member
    Jul 15, 2005
    Illinois
    You're right of course. The smaller is 80% of the larger which means the larger is 25% larger than the smaller. The % difference depends on which one you use as the base, and I used the large one which is not what we are trying to determine.
Similar Threads: Does trap
Toilet Forum discussions "Fully Glazed Trapway" What does that really mean? Dec 11, 2014
Toilet Forum discussions when using unift 14 inches does the trap stay the same Apr 23, 2010
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Feb 15, 2017
Toilet Forum discussions Uneven tile so flange does not sit on top Dec 19, 2016
Toilet Forum discussions Does Toto make a Toilet with Washlet or is the Washlet always an add-on? Dec 2, 2016
