Does this Tub have a Mortar Bed?
Discussion in 'Shower & Bathtub Forum & Blog' started by yoyoma, Aug 19, 2008.
  1. yoyoma
    yoyoma New Member
    Jul 26, 2008
    Can anyone tell me whether this tub has a mortar bed judging from the photo? I don't have access so stuck my camera through the side and took this photo:
    [​IMG]
    Thanks.
  2. Bob the Builder
    Bob the Builder New Member
    Aug 18, 2008
    Builder and constructor of sanatation disposal and
    Bobsville
    It appears not. Depending what type of tub that was installed it may not need a mortar or plaster bed. It looks like it might be a 1 pcs tub install, if that's the case I would say your fine without it unless your having problems other than you have stated. Is that tub on a slab? I read some other statements and thats what I gather. We do that in Bobsville.
  4. yoyoma
    yoyoma New Member
    Jul 26, 2008
    It's a Maax Modest:
    http://www.maax.com/en/Products/ProductInfo.aspx?Brand=8&CodeCategory=B&ProductType=1&Product=288
    This is what the instruction manual states: "To provide additional support, improve soundproofing and facilitate leveling, it is recommended that a layer of mortar or plaster be applied to the base of the bathtub legs, and covered with a 1/16†(2mm) polyethylene sheet. The layer should be thick enough to facilitate the leveling of the unit without raising it."
    I spoke to Maax customer service and they said if you're under 300 pounds you really don't need it, but they recommend it.
    My GC said that the plumber told him he put in a mortar bed. I told my GC that I took a photo (because I can't fit my head through to see) and didn't see it but am not 100% sure. He said the bed will be right in the middle at the bottom so you won't be able to see it unless you go to the crawlspace and look up. There is plywood underneath, not slab.
  5. Master Plumber 101
    Master Plumber 101 In the Trades
    Aug 11, 2008
    Wisconsin
    Does the base of the tub feel solid? Looking at the picture I can't tell you if there is a morter bed in the center of tub.
  6. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    All Maax tubs have been recommened to have a mortar bed. Its alawys a good idea when installing any acrylic tub, regardless of legs or wafer board bases. You have less flexing in the tub with mortar under pads/bases installed.
  7. yoyoma
    yoyoma New Member
    Jul 26, 2008
    Can you tell whether there is a mortar bed in there based on the photo?
  8. yoyoma
    yoyoma New Member
    Jul 26, 2008
    I went back to check on it, and squeezed my hand underneath the front right section next to the drain, and there is no mortar bed there. Is this normal? However, I took another photo which does show a mortar bed:
    [​IMG]
    So I guess everything is copacetic.
  9. Terry
    Aug 17, 2004
    Looking good.
    The funny thing about all this,
    Manufacturers never used to tell how to install tubs with mortar.
    It wasn't until I added the instruction to a Hydroswirl page I copied and posted on the net.
    Now, because of the Internet, more and more plumbers have tried it, and it has become, "The way to do it"
    Not that a few people weren't always doing it, but now it has become part of the plumbing industry standards.
Similar Threads: Does Mortar
Shower & Bathtub Forum & Blog Does it make sense to do a whole floor in fiberglass? Feb 4, 2017
Shower & Bathtub Forum & Blog New tub level, but doesnt drain water all the way Nov 14, 2016
Shower & Bathtub Forum & Blog How does shower line drain through tub spout when valve is off and diverter is set to tub? Apr 3, 2016
Shower & Bathtub Forum & Blog Does this shower drain need to be redone? Mar 10, 2016
Shower & Bathtub Forum & Blog Shower Handle Doesn't Turn + No Hot Water Dec 24, 2015
