Does this make sense?
Discussion in 'HVAC Heating & Cooling' started by rayh78, Jul 20, 2013.
  1. rayh78
    rayh78 Member
    Sep 15, 2008
    Colonial Heights, Virginia
    What seer do I have now?
    Gas furnace. Had to replace ac unit last year. Went with a A coil new lines for 410a and then outdoor unit a heat pump. To just run in ac mode for now. Was not that much more for the option to later switch to a heat pump. Not interested in dual fuel for now. A Rheem 2 ton classic series 13 seer
    Anyway was not cooling good. Had another guy look at it that seems to know his stuff. Said the first guy did not do a good job with installation no filter/dryer.
    First Freon but said the pressures did not look right, but lets see what happens.
    Next came TXV valve was clogged and he replaced. 24 hours later same problem. New guy said there was still junk in the line and TXV was harder to work on. So they did something and deleted or bypassed the TXV and put in a piston valve? And at the same time finally added a filter/dryer.
    Said it would only lower the efficiency.
    What do you think?
    Thanks
Similar Threads: Does sense
HVAC Heating & Cooling Does this make sense? Apr 6, 2009
HVAC Heating & Cooling Aprilaire dehumidifier 500A not working but test does Dec 8, 2016
HVAC Heating & Cooling Blower won't come on on "auto" but does with "on" Oct 29, 2016
HVAC Heating & Cooling Replaced heat pump cap. does it need to charge? Aug 12, 2016
HVAC Heating & Cooling Does running two trunklines address the problem of trunkline duct being too small Nov 19, 2015
