does double kitchen sink require two traps?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by marktd, Aug 17, 2014.
  1. marktd
    marktd New Member
    Aug 17, 2014
    or can both go through one? Anything not kosher about that shown in attached pic?
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    One trap is fine. The trap arm should not dip down the way you have it, but it might work.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    It doesn't but sometimes it's easier to do it that way. I don't like what you have there because the disposer is going to and water flying towards the sink basket.
  5. hj
    They have the wrong fitting where the two drains join and the trap arm has a partial "S" tarp. Someone got very creative and spent a lot of time making that mess.
    SHR likes this.
  6. marktd
    marktd New Member
    Aug 17, 2014
    I think the reason for the bend in the trap arm is that if it were horizontal, the drawer would hit the trap. Is there some concern about that bend? I could get rid of the dip by notching the drawer.
  7. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Yes. An alternative to notching the back of the drawer would be to locate the trap to the right over the lower and backless drawer.
  8. marktd
    marktd New Member
    Aug 17, 2014
    Actually, the right side has same drawer. It's just not visible because the drawer is pulled out to allow picture to be taken.
    I think a more conventional layout with slip joint fittings might fit without drawer trap interference. For example, the disposer rotated so outlet points toward other sink, sink drop tube, tee, etc. But that would interfere with the waste basket arrangement in the right drawer (not visible in picture). The current setup was an attempt to push the drain close to the wall to maximize space.
    It works now, but as Tom Sawyer above guessed, the disposer pushes water into the other sink basket. So I am looking to fix that, but try to preserve the waste baskets.
  9. hj
    "convenience" is never a reason to do it incorrectly. We would have to see the actual installation, with the drawers in place to determine the better way to do it.
  10. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Just curious, are plumbers working under the UPC putting two traps on one trap arm and getting away with it? Unless it has changed in the last few years, 1001.1 states, "Not more than one (1) trap shall be permitted on a trap arm." We got called on it in the Los Angeles area, back in the day - but it sounds like it may be a common practice other places. The law is as the law is inforced, is this a case where inspectors put fingers in their ears and hum? Has the code change since 2000?
  11. SHR
    SHR Member
    Mar 9, 2014
    Journeyman Plumber
    Minnesota
    You have an S-trap. S-traps are dangerous. Correct the plumbing.
Similar Threads: does double
Plumbing Forum, Professional & DIY Advice Two quotes - difference of more than double? (pricey one doesn't even break cement) Sep 16, 2011
Plumbing Forum, Professional & DIY Advice New Drain lines in bathroom - does it look right? Mar 29, 2017
Plumbing Forum, Professional & DIY Advice Clean out cap spins does not come out Mar 23, 2017
Plumbing Forum, Professional & DIY Advice Does anyone recognize this shower valve? Mar 20, 2017
Plumbing Forum, Professional & DIY Advice Shut-off valve - angle or straight, does it matter? Mar 5, 2017
